my compression test results
Old Dec 10, 2002 | 10:38 PM
irev210's Avatar
Default my compression test results
210 210 215 210 (wet compression test)
bone stock 1988 crx HF
153k miles
not too shaby i think
Old Dec 11, 2002 | 05:33 AM
USDM 4G VTEC's Avatar
Default Re: my compression test results (sirhatchback)
hell no
those are damn good number.... seems u dont have any problems with worn rings, or bad valve seats.....
anyways , dont let that fool u . maybe some day it might go away ... at least it tells u who ever u bought it treated it good...
Old Dec 11, 2002 | 02:50 PM
k_spek's Avatar
Default Re: my compression test results (JDM EF9)
yah seriously....
hopefully it will last long enough till i swap motors
HF power baby
Old Dec 11, 2002 | 02:55 PM
333's Avatar
333
Default Re: my compression test results (laugHin22CX)
I have 168900 and I burn a little oil in my hf, like then I go 3rd to 2nd doing 55 mph. I would be afraid to do a comp. check. Still get 40 or so miles to the gallon.
Old Dec 11, 2002 | 02:58 PM
matt j's Avatar
Default Re: my compression test results (333)
my compression was around 185 185 190 194 i think that was pretty good but damn yours is awesome
edit: i have around 201,000 miles on mine
[Modified by hybridturbo89, 3:58 PM 12/11/2002]
Old Dec 11, 2002 | 03:25 PM
bleebdat's Avatar
wet means fuel is still running i assume?
mine from 3 days ago on my y8/z6 combo was between 200 and 210 across the board.
Old Dec 11, 2002 | 04:25 PM
EG8R's Avatar
Default Re: my compression test results (bleebdat)
How many cranks do you guys usually do when doing the test???
Old Dec 11, 2002 | 05:43 PM
sporkcrx's Avatar
Default Re: my compression test results (mr. skelly)
Jesus ****, what are the numbers suppossed to be? Before I put my turbo on it was 150 across....I wonder what it is now
Old Dec 11, 2002 | 06:53 PM
matt j's Avatar
Default Re: my compression test results (sporkcrx)
on mine i cranked it until the needle evened out, and i also disconnected my injectors when i did it
Old Dec 11, 2002 | 06:56 PM
Malgerus's Avatar
Default Re: my compression test results (hybridturbo89)
All that carbon sure raises the compression
Old Dec 11, 2002 | 09:46 PM
irev210's Avatar
Default Re: my compression test results (Mr. S)
i thought wet was just warm'd up...
i just cranked it 5 times, if i would have kept cranking, im sure it would have gone up more.
aj345
Jun 2, 2013 07:58 PM
Travis R
11
Jun 30, 2011 06:39 PM
adictionbass
Sep 22, 2006 06:40 PM
Chris F
Nov 1, 2004 09:08 PM
m0t0rhead
Feb 11, 2004 06:37 AM
