Cam Gear weight: AEM vs. Skunk2
For inquiring minds that want to know, Skunk2 cam gears are lighter than AEM cam gears.
I have both of them right here the AEM is defintely heavier. You can pretty much already tell because the skunk2 a smaller internal piece, but anyways it's lighter so I expect it spins better freeing up hp!
Every little bit helps
[Modified by satan_srv, 2:25 AM 12/11/2002]
Skunk2 cam gears are really nice especially when you consider they can be had for under $200 shipped if you look around. I doubt you'll notice a difference from the weight though even with oem cam gears.
it's the same concept as lightweight wheels...rotating mass has a big impact when you consider weight.
I'm gonna guess the stock gears are even heavier....I was surprised at the difference between the AEM and Skunk2...
Skunk2 gears plus my super strong belt = one badass rotating assembly!
just out of curiosity....what belt are you running satan?....ive only heard of one belt for an h series motor besides the oem belt....and im curious to hear if you have any -/+ feedback on it. thanks
i got SKUNK2 cam gears on my car. just installed them last week. i have to tune them though...
do you guys have clearance issues? mine rub somewhere making this whistle-like sound. people think i have a supercharger... i removed the top cover, but from what i hear i need to remove the bottom one as well. is this true? if so, i got a project to do this weekend.
the skunk 2's are still lighter then the new aem ones. my girl has aem, i have skunk 2.
to the guy who was rubbing, did you take the cover between the cam gears and the head off?
While we are on the subject of cam gears, i was thinking of getting some AEM's but one of my friends told me that they can do more harm than good on your engine by decreasing the engine life is this true?
oh, when you said bottom, i was thinking lower, as in the one near the crank pully. if i was you, i would just cut the one behind the gears off. screw taking the timing belt off to get that out.
used to run skunk2's on my h22a about 2 years ago. i personally didn't like the the actual quality of the gears.
str used to have the best ones in my opinion.
Im ordering some cam gears for my F22A1 here shortly...
I think ill go skunk2...
but really how much HP will you gain?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeprojex »</TD></TR><TR><TD CLASS="quote">whats the installation cost on cam gears (average?)</TD></TR></TABLE>
whoa old school post. Usually cam gears are installed with new cams, so whatever a cam install costs cam gears are usually included.
I had 3 to compare... the h22a skunk2 i had were extremly lighter than aem... also to fit the new style skunk2 you need to grind the plastic part of the cover.. (the half moon to clear, because the bolt is exactly the lenght needed to fit.. so when you clear the spacing you actually go through the plastic.. here is a pic to compare..
look at the plastic cover...
this is my h22a built motor for my ek, mind you the headers different,so is the intake and other things
More PoWA!
ahhaah
More PoWA!
ahhaah
