I Need Help!
Old Dec 10, 2002 | 09:25 PM
HybriDNA's Avatar
Default I Need Help!
Ok here's the deal. I have a 89 crx. I swapped in a 93 b18a and have a 91 OBD-0 ECU. Will a 93 Integra Wiring harness work with little modification? If so what?
Old Dec 10, 2002 | 09:26 PM
USDM 4G VTEC's Avatar
Default Re: I Need Help! (Project_Rex)
i think u can use ur stock harness on the engine.. jhust add a few wires....
Old Dec 10, 2002 | 09:57 PM
EF_LSVtec's Avatar
Default Re: I Need Help! (JDM EF9)
jdmef9 is correct, just use your stock wires but you need to wire each injector and injector resistor box (mpfi) . Considering you already replaced your injectors and distributor to non obd.
nicko360
Mar 22, 2007 12:34 PM
Dohc 4door Rye
Nov 15, 2005 05:13 PM
WickedWerx
Jun 28, 2004 03:33 PM
Mr. UnderHill
Nov 26, 2003 09:18 AM
SOHCEK-Turbo
Oct 20, 2003 01:20 AM
