how do i wire a 93 ls motor into a 94 si delsol harness?? HELPPPPPPPP
what the heck is the easiest way to wire up a 93 ls swap into a si 1994 delsol??? none of the plugs plug in so i cut the ones out of the integra....can i just match the wires and run them and butt connect them color to color??? or do i need the whole harness out of the integra to do it? i have already plugged in the ecu and that went right in. motor is in the car ready to go just need help on the wiring...please help ASAP...thanks
andy
andy
Re: how do i wire a 93 ls motor into a 94 si delsol harness?? HELPPPPPPPP (WickedWerx)
You cannot use the integra harness.
You need to modify your stock harness to fit the b18a.
The only reason you may need the integra harness is to salvage some of the connectors off of it(if you dont have them laying around).
I believe the '93 integra injectors still used the injector resistor box, so you will need to wire that in.
Or you could get some '94-'95 injectors and then not only would you not need the resistor box, but then wouldnt need to swap out injector plugs.
Also, I dont think its a good idea to use butt connectors. You should solder all of your splices.
Good luck.
Good luck.
1 Post
you will need to convert the motor to obd1 basically, obd1 injectors, alternator, distributor and all will be plug n play.
Re: how do i wire a 93 ls motor into a 94 si delsol harness?? HELPPPPPPPP (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">you will need to convert the motor to obd1 basically, obd1 injectors, alternator, distributor and all will be plug n play.</TD></TR></TABLE>
The '93 integra motor is obd1.
