Clutch cable- OEM or aftermarket?
Old Dec 10, 2002 | 07:41 PM
tylerdurden's Avatar
Default Clutch cable- OEM or aftermarket?
My cable is squeaky and the pedal effort seems high compared to most other cars I drive. So I'm shopping for a new one and I want to know if it is worth more money to get an OEM cable or are aftermarket cables basically the same? What should I be expecting to spend?
Old Dec 10, 2002 | 07:54 PM
Redline130's Avatar
Default Re: Clutch cable- OEM or aftermarket? (tylerdurden)
OEM, can't beat the quality. Also, I don't think anyone makes an aftermarket one.
Old Dec 10, 2002 | 08:13 PM
EF_LSVtec's Avatar
Did you try adjusting the cable to your preference? You can adjust the tension on the cable itself. Check the cable connection on the tranny and it can be adjusted by turning the "adjustment wheel".
Old Dec 11, 2002 | 10:10 AM
Default Re: Clutch cable- OEM or aftermarket? (EF_LSVtec)
So, anywhere I find one it is an OEM cable? I looked online and found them anywhere from $27-$40. They are all the same cable, just different prices?
The adjustment just changes the takeup point, yes? I don't really need to do that. I'm just trying to get rid of the squeak and hopefully soften the pedal somewhat.
[Modified by tylerdurden, 7:11 PM 12/11/2002]
Old Dec 11, 2002 | 01:23 PM
kranked91dx's Avatar
No you can found crapp at pep-boy, I call I crapp, but I don't even have tried it. I bought cheap Peppy rotor one time, they were the worst POS I have ever seen.
they tweacked in about 3 week.
Old Dec 11, 2002 | 03:31 PM
CRVRX's Avatar
Default Re: Clutch cable- OEM or aftermarket? (kranked91dx)
The squeek is comming from the release bearing , not the cable. The Honda clutch cable is the beat you can get, Get one for a 90 Integra if you have a b16 or a 90CRX Si.
Old Dec 11, 2002 | 04:33 PM
E-AT_me's Avatar
Default Re: Clutch cable- OEM or aftermarket? (CRVRX)
check out http://www.hondaautomotiveparts.com
i am using a standard Si cable for my b16a swap. it works just fine..
Old Dec 11, 2002 | 05:06 PM
keebler65's Avatar
Default Re: Clutch cable- OEM or aftermarket? (Rexman)
and as far as "softening" it up, thats most likely 100% dependent on what style pressure plate you have as well as how much wear it has. i think as clutches wear out, the pedal becomes harder to push if i remember correctly
2x0
17
Apr 4, 2019 08:52 AM
redDAinteg
Nov 20, 2008 02:01 PM
MapofurheadCrx
Jan 27, 2005 09:51 PM
90 Si Hatch
Dec 20, 2004 11:18 PM
DigitalFusion
Jul 22, 2004 10:50 AM
