PCV valve location
Where does the PCV valve conect to the block? It starts at the top of the intake and them goes through between the 1 2 intake runners and then connects to what? thanks in advance...
it aint even be tryin to connect to the block, doo. j/k it goes down into a little black box kind of under the intake manifold. just pull on it. its in a rubber gasket thing in the top of that black metal positive crankcase ventilation box. it really helps too if you mention what car you have. so this is really just an educated guessaroni.
efjones9
Apr 20, 2009 09:01 AM
K i l l a B e e.
Mar 4, 2009 10:31 AM
