99 b18b into a 93 eg hatch
i know that its obd 2(the motor)...some how this guy i know is using a obd2 ecu on the hatch. (i might trade for this hatch) what will i need to do to convert it to a obd1? what is the code for the obd1 ls ecu? pr4? the check engine light is on and i dont know why.
is it plug and play? anything changes in the harness?
any info would help...thanks
the obd1 LS ecu is P75(well mine is)...it has three plugs instead of four found on the obd2 ecu...it should be all plug and play also, so use the engine wiring harness for that motor and plug into your civic chassis harness....you might have a spare plug at your shock tower but don't worry about it....here's a pic that shows the difference between obd1(top) and obd2(bottom):
[Modified by 95hbMatt, 5:47 PM 12/10/2002]
i know that its obd 2(the motor)... some how this guy i know is using a obd2 ecu on the hatch .
I believe the Pr4 ECU was used on the 92-93 B18a equipped Integra...
[Modified by JV, 9:48 PM 12/10/2002]
i have no idea what ecu he's using. he told me that he has a extra plug out. the check engine light is on. can i use the stock eg harness and use a obd1 ecu?
obd1 ls ecu is p75
what he said
G
[Modified by g_man80, 12:11 AM 12/11/2002]
