header bolts
well i while back i put a set dc sport header on my car. the problem is when i got them i on i could not bolt it to the cat theat easy but after clamping and what not i got them on there. well that weekend i was racing one of my friends and the header pulled off the cat. not a big deal the bolt still there then the next morning i tighten them back down. that night i got on it again and the bolt did not just get lose in was gone so i went to wall mart at midnight got a bolt nuts and washers and ghetto rigged it is this wise
instead of using the bolt with the spring and what not on it. i just used bolt and five washer then a lock washer the the nut to connect the header to the cat. Is this a good idea by not using the springs
I'd get a spring bolt set from honda, it allows flex in the system. So the catback and header dont get strained from being a solid piece when the car flexes.
well i while back i put a set dc sport header on my car. the problem is when i got them on i could not bolt it to the cat theat easy but after clamping and what not i got them on there. well that weekend i was racing one of my friends and the header pulled off the cat. not a big deal the bolt still there then the next morning i tighten them back down. that night i got on it again and the bolt did not just get lose in was gone so i went to wall mart at midnight got a bolt nuts and washers and ghetto rigged it is this wise
Dang, you have a V 8 in your car!...j/k
Kyles ej1
Oct 6, 2005 11:54 AM
