My car idles too high!!
Old Dec 10, 2002 | 02:15 PM
blacksheep's Avatar
Default My car idles too high!!
My car is idling too high.. around 1500-2000 rpm. Why?
Old Dec 10, 2002 | 02:22 PM
Spade's Avatar
Default Re: My car idles too high!! (blacksheep)
Maybe a vaccum hose wore through.....check all.
Old Dec 10, 2002 | 02:30 PM
blacksheep's Avatar
Default Re: My car idles too high!! (Spade)
where can i get vacuum hoses besides from the dealership? if they're not expensive, i'll replace them tomorrow. they're probably not expensive from the dealership either huh?
Old Dec 10, 2002 | 04:26 PM
BoostedH23a1's Avatar
u probably have a Vaccum leak. take a propane torch (dont light it) turn it on so propane is comming out. crank the car and take the propane and run it around the lines. the engine will idle higher if propane gets into the motor. once u found the area isolate the line and replace as needed. u can get vaccum line from carquest, auto zone.... its 5/32 size for yours probably.. if its not vac lines check your throttle body screw and the throttle cable tension..
Old Dec 11, 2002 | 08:06 AM
cinq's Avatar
Default Re: My car idles too high!! (BoostedH23a1)
This seems dangerous...for a newbie...wouldn't it be better to get a can of starter fluid and spray around it?
Old Dec 11, 2002 | 09:50 AM
Default Re: My car idles too high!! (cinq)
propane is safer. ether knocks like a bitch..
Old Dec 11, 2002 | 03:05 PM
blacksheep's Avatar
Thanks guys.. I'm gonna try that when I get off work. I'll post my results later.
premier_ek9
Sep 18, 2007 12:00 AM
adamjenkins80
Apr 15, 2005 09:04 AM
prelude9999
Oct 8, 2004 10:01 AM
.cingham
Apr 10, 2004 08:55 PM
evo
May 1, 2002 01:25 AM
