ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result?
Old Dec 10, 2002 | 01:06 PM
KevronsEG's Avatar
Default ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result?
i have 91 crx and i put luminas on there with some 4th gen sprinsg i i'm not sur eif its right should i have used 5th gen springs
Old Dec 10, 2002 | 01:13 PM
KevronsEG's Avatar
Default Re: ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result? (CIV616)
i put the 5th gen struts on with 5th gen forks and it sits kinda high. so i put stock struts with the spring and i coudlnt even get the spring. on so i had to do it with teh top mount in the car and then put teh rod up, then lower teh car to screw it on. then it sat the same as with teh fith gen struts, so i have no idea
[Modified by CIV616, 10:26 PM 12/10/2002]
Old Dec 10, 2002 | 01:19 PM
d357r0y's Avatar
i put the 5th gen struts on with 5th gen forks and it sits kinda high so i put stock struts with the spring and i coudlnt even get the spring on so i had to do it with teh top mount in the car and then put teh rod up and then lower teh car to screw it done. and then it sat the same as with teh fith gen struts so i have no idea
withalmostnoperiodsorcommasimhavingahardtimefiguri ngoutwhatyouaretryingtosaynotthatithinkthisstringo fwordswouldevenmakesenseifithadsomepunctuation.
Old Dec 10, 2002 | 01:26 PM
KevronsEG's Avatar
Default Re: ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result? (d357r0y)
F/O i'm looking for info not this shiz
Old Dec 10, 2002 | 05:36 PM
KevronsEG's Avatar
nobody
Old Dec 10, 2002 | 05:44 PM
shorti's Avatar
withalmostnoperiodsorcommasimhavingahardtimefiguri ngoutwhatyouaretryingtosaynotthatithinkthisstringo fwordswouldevenmakesenseifithadsomepunctuation. <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emsmilep.gif" BORDER="0">
good call
Old Dec 10, 2002 | 07:06 PM
neutron91's Avatar
Default Re: ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result? (shorti)
i would buy what's made for my car
Old Dec 10, 2002 | 07:09 PM
Digitalcivic's Avatar
Default Re: ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result? (neutron89)
but yea, 4th gen springs and struts are right.
srg
Feb 28, 2009 10:24 AM
InvaderTrax
Oct 30, 2005 07:15 AM
shadowz
Jun 14, 2004 12:04 PM
4thgenlude
Jan 24, 2004 04:33 PM
vinuneuro
Jan 15, 2004 09:24 AM
