ls vtec is still overheating
Old Dec 10, 2002 | 12:14 PM
ls_vtec_b18a1's Avatar
Default ls vtec is still overheating
this is what i got once again a b18a1 block with b16 pr3 pistons on ls rods, a b16 head, new b16 water pump, oil pump, head gasket the b18 that is. and its overheating when i put my thermostat in. i blead the air out the system and the fans are wiried to run all the time, the top hose on the rad. will get hot but the bottom one wont. this is the second thermostat that i have tried. and i also get no heat. my temp a gauge will got to 250 then i cut it off and the thermo is a 180. what should i do
Old Dec 10, 2002 | 02:45 PM
riceboyEFsi's Avatar
Default Re: ls vtec is still overheating (ls_vtec_b18a1)
i had this problem w/ my ls/vtec , coolant is not overflowing and bubbling in the overflow tank, is it?
Old Dec 10, 2002 | 04:42 PM
Default Re: ls vtec is still overheating (riceboyEFsi)
no i dont think it is
Old Dec 10, 2002 | 05:01 PM
tnbigdawg's Avatar
did it over heat before you wired your fans to run all the time?
Old Dec 10, 2002 | 05:15 PM
Default Re: ls vtec is still overheating (tnbigdawg)
yea it did
hondamanshawn
Jan 22, 2016 11:17 AM
91da_teg
Jun 8, 2012 07:19 AM
91boostedb2o
Jul 29, 2009 12:31 PM
notburton06
Jul 20, 2009 11:15 PM
boostonthebrain
Jan 11, 2007 09:42 PM
