Type R cat?
Old Dec 10, 2002 | 06:42 AM
(__________)'s Avatar
Default Type R cat?
Ive searched and cant find anything.
Will a Type R cat bolt up to a GSR or is it too short?
Old Dec 10, 2002 | 06:44 AM
Nate B's Avatar
Default Re: Type R cat? (steves98itr247)
Too short or too long, not sure which, but I'm pretty sure it won't bolt up properly.
Old Dec 10, 2002 | 06:50 AM
Chris N's Avatar
Default Re: Type R cat? (Nate Bizzle)
I think the type R cat is too long for a GSR with stock header/exhaust.
Depending on whether you have an aftermarket header and/or exhaust, it could fit.
PM-Performance's Avatar
Default Re: Type R cat? (Chris N)
type R cat is longer than the GSr if that helps
Old Dec 10, 2002 | 07:04 AM
Default Re: Type R cat? (itr206)
is the GSR header longer? What if my stock header and cat were bolted up on a GSR?
Old Dec 10, 2002 | 07:09 AM
i think the headeras are the same almost except for where the o2 is mounted? from what i remember , but the bpiping is longer on the GSR than the Ls /Type R ,.
Old Dec 10, 2002 | 07:13 AM
thanks man
Old Dec 10, 2002 | 07:15 AM
Chris N's Avatar
cat is shorter, exhaust is longer. same length header.
Old Dec 10, 2002 | 07:29 AM
Nate B's Avatar
I've been told that the whole type r exhaust system will not bolt up to a GSR mainly becaust of 02 sensor locations. I'm sure things could be modified to make it fit.
Old Dec 10, 2002 | 07:49 AM
it can be , i extended mt secondary o2 already
Old Dec 10, 2002 | 01:07 PM
B2FiNiTY's Avatar
I believe it all bolts up to 00-01 GSRs.
Old Dec 10, 2002 | 07:53 PM
ITR#132's Avatar
Depends on What year GSR, But I believe that all cats are the same size.
kroy546
Feb 3, 2009 09:56 PM
ek82
Oct 15, 2007 05:07 PM
SleeperGSR
Oct 1, 2007 03:16 PM
S2KILLA
May 31, 2004 09:24 PM
RAS Motorsports
Mar 21, 2004 07:43 PM
