ultimate tar removal guide!!!
Old Dec 9, 2002 | 11:47 PM
GARBhatch.'s Avatar
Default ultimate tar removal guide!!!
Yes this is a question, and hopefully this will finally set a lot of rumors aside... at least for a day or so... I have been looking for the best way to shave lbs. recently and started to take the tar out of my ek... Well as most of you already have experienced, it is a BIOOOOTCH... One thing which i have already learned and will contribute- the colder it is outside the easier it will be to get big chunks of it..MMMMM...tar. well i have heard these following things, can someone who REALLY knows please dispel any rumors and clarify on the topics.
1.) lighter fluid? raising the oh-so obvious question... SAFE?
2.)dry ice- i can understand that (but how exactly) also i heard pour alcohol on it while it is crushed and sitting on the tar-no joke!
3.)hammer, chisel, & simple green or whatever it is, which i have personally tried on the leftover black gunk but does not come off at all...
if you can clarify this you will be H-T GOD.. maybe. thanx in advance
Old Dec 10, 2002 | 12:09 AM
Dj Lotte's Avatar
Default Re: ultimate tar removal guide!!! (98Hatch22a)
I'm using a heat gun right now...this is however taking forever!!! Gonna take a whoel weekend at the pace I found my self crawling through this process...
Old Dec 10, 2002 | 12:51 AM
BenB's Avatar
I've tried everything but the lighter fluid, and lighter fluid isn't that abrasive. Heat guns suck.
Dry ice is the key. I just leave the dry ice in the bag and set it on top of the area I plan to work on. Let it sit for a few minutes.
Tap the area firmly with a hammer to break it up then use a chisel & hammer to work from the edges. Patience.
Use 3M Tar Remover to clean up the left-over residue.
I have done 3 cars this way, all in one night with the help of a friend or two.
[Modified by BenB, 9:53 AM 12/10/2002]
Old Dec 10, 2002 | 06:40 PM
jas0n's Avatar
Please don't hurt me!
Default Re: ultimate tar removal guide!!! (BenB)
where do you find that i got everything off except residue heh
i wouldnt not recommened doing this waste of time and money
[Modified by couter, 10:40 PM 12/10/2002]
Old Dec 10, 2002 | 06:45 PM
ArinX's Avatar
Default Re: ultimate tar removal guide!!! (couter)
i have a ek also how much weight can be lost this way??
Old Dec 10, 2002 | 07:12 PM
Paranoid Android's Avatar
Default Re: ultimate tar removal guide!!! (ArinX)
where would the tar be located? i dont know of any tar on my car.
Old Dec 10, 2002 | 07:13 PM
Slow CX's Avatar
What is this and where is it.
Old Dec 10, 2002 | 07:14 PM
BARF1's Avatar
Default Re: ultimate tar removal guide!!! (Paranoid Android)
look under carpet
Old Dec 10, 2002 | 07:16 PM
Slow CX's Avatar
Default Re: ultimate tar removal guide!!! (BAR-F1)
I have no carpet. Nothing there just metal.
Old Dec 10, 2002 | 07:17 PM
ejprimo's Avatar
on your floor board, under the rear seats, and a little in your trunk.
Old Dec 10, 2002 | 07:43 PM
Slow CX's Avatar
Default Re: ultimate tar removal guide!!! (ejprimo)
Please show me. I have done nothing to this but wipe it down.
Old Dec 10, 2002 | 07:45 PM
oldskool_rex's Avatar
Default Re: ultimate tar removal guide!!! (Slow CX)
CXs don't have it silly.
I watched some guy get it off really fast with an air hammer and a chizel attachment
Old Dec 10, 2002 | 07:47 PM
navin's Avatar
CX = no rear tar. it should be in the driver/passenger foot areas and behind them too when you take out the seats. there is some behind that firewall matt too..
Old Dec 10, 2002 | 08:14 PM
ArinX's Avatar
Default Re: ultimate tar removal guide!!! (navin)
what about 2000 hatch cx? Does that apply to that too??
Old Dec 10, 2002 | 09:17 PM
Blown90hatcH's Avatar
No that has tar all over it. I shaved like 12lbs when I removed all my tar from my 00 cx hb. It took me about 2 hrs. Very clean and fast. 8lbs dry ice + 2 bottle rubbing alcohol + air chisel = 2hrs - 12lbs - clean floor.
Old Dec 10, 2002 | 09:42 PM
.Ryan's Avatar
Don't Trust Anyone
Heat guns suck.
w3rd.
Old Dec 10, 2002 | 09:59 PM
Slow CX's Avatar
Default Re: ultimate tar removal guide!!! (SpoonSportsEH2)
Where can I buy some dry ice.
Old Dec 10, 2002 | 10:07 PM
BenB's Avatar
I got mine at walmart y0!
Old Dec 10, 2002 | 10:08 PM
BenB's Avatar
Grocery Store.
Ivan's Avatar
senior gold member
Its pretty cold outside. Should I use the dry ice too to make it easier?
Old Dec 10, 2002 | 10:09 PM
BenB's Avatar
20~25lbs in my DX Coupe, the hatches have slightly less.
Dr. EKology's Avatar
Local drug store should have it.
rc1320's Avatar
Does anyone have after pics...
Have you guys been able to remove the tar without scratching the paint off?
Old Dec 10, 2002 | 10:10 PM
BenB's Avatar
Default Re: ultimate tar removal guide!!! (Ivan)
It can only help, and its not that expensive, 5 bucks max. The colder it is outside, the more life you get out of your dry ice.
Old Dec 10, 2002 | 10:13 PM
Ivan's Avatar
senior gold member
Default Re: ultimate tar removal guide!!! (Blown90hatcH)
I heard the dry ice and alcohol is the best. Is there any precaution I should take if I went this route?
