Brakes...help!!
Ever since the cold weather i believe one of my back brakes is stayin locked on...i can feel that for the first 3 or 4 notches on my ebrake its very loose after the 4th or so it tenses up how its supposed to be..some one help please!
Your ebrake cable is probably frozen or stretched and just needs adjusted. As long as the symptoms metioned above aren't obvious, you should be okay. Lube it or try to work it loose. Do you use your ebrake often?
sleepystyle
Jan 11, 2006 01:15 PM
