jumper harness
Old Dec 9, 2002 | 07:05 PM
pwr5hift27's Avatar
Default jumper harness
do i need to use a jumper harness when im using a 97+jdm h22a into my 97 accord ecu? or can i use my accord ecu with the h22a??? do i need to use the jumper harness for a 92-96 h22a??
Old Dec 9, 2002 | 08:24 PM
KTeller8's Avatar
Default Re: jumper harness (pwr5hift27)
hey there, ok first off if you can use your accord ecu, but realisticly you wont see full gains and benifits out of it..
you can use 96+ecu's
if you want to run a 92-95 in your obd2 car you will need a obd2-1 harness, which i can provide to you for 170, this will allow you to plug in a obd1 ecu, which are cheaper, programable and easier to find... and your set to go
RACEPAK
Jan 28, 2011 03:31 AM
tunerraceteam
Feb 22, 2009 03:49 PM
FunnyVictor86
Dec 28, 2008 04:15 PM
pwr5hift27
Dec 9, 2002 10:23 PM
