No speedometer after Quaife install??
Old Dec 9, 2002 | 06:06 PM
NVMYSi's Avatar
Default No speedometer after Quaife install??
I just got a Quaife in my 00 Si and now the speedometer won't work, what could be the issue? Everything seems to be hooked up properly. If people could give me some ideas on what and how to check things I would be very thankful. If somebody suggest the VSS could they tell me how to check if its bad.
Old Dec 9, 2002 | 07:23 PM
DA MUGEN 1's Avatar
Default Re: No speedometer after Quaife install?? (NVMYSi)
Sounds to me like a speed sensor problem look around the speed sensor area and make sure all electrical connections are connected
Old Dec 9, 2002 | 07:33 PM
tegasaurus's Avatar
Default Re: No speedometer after Quaife install?? (DA MUGEN 1)
Old Dec 9, 2002 | 07:43 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: No speedometer after Quaife install?? (tegasaurus)
speed sensor is suspect... imo.. good luck
Old Dec 9, 2002 | 09:28 PM
InevitableRace's Avatar
Did it work before the install??
If it did then thats not it...The reason i say that is because you have a 00 si...chances of that going bad is slim....for being a 00..
the only thing i can think of is you forgot to put the speedo ring back on the Quaife..
Or you dont have the speedo pushed all the way in...IF you take out the speedo you might be able to see down the hole and look for some type of Gear looking thing if thats not there the the ring isnt there..
Good luck
Thanks
Ross
Old Dec 9, 2002 | 10:06 PM
Kataku2K3's Avatar
Default Re: No speedometer after Quaife install?? (allmotrb18c1)
Do you have a CEL perhaps throwing a code 17?? IF so check to make sure the VSS connector is plugged onto the VSS.
Exactly what I was thinking if all the electrical checks out good... Latez
Old Dec 9, 2002 | 10:33 PM
earl's Avatar
Default Re: No speedometer after Quaife install?? (JDMspecEG6)
Did you install the gear on the Quaife before you put it inside the tranny? You have to pull the old one off and press it on to the wuaife.
Edit: Oh sorry, someone else already said that but that's where I would look first
Old Dec 10, 2002 | 12:07 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: No speedometer after Quaife install?? (earl)
I know some people have already said this, but it looks like they didnt install your spedo gear. See the gear Im heating up here? That is what you have to press off of the stock diff and then press it on the quaife.
Im willing to bet that is your problem, and not an electrical problem like everyone is talking about.
art
Old Dec 10, 2002 | 12:32 AM
b00stn's Avatar
Care to comment on the Quaife itself? Have you had a chance to try it out?
Old Dec 10, 2002 | 04:47 AM
Ricky Rojales's Avatar
Default Re: No speedometer after Quaife install?? (Arturbo)
art
I agree, and be very careful with the removal. Breaking a speedo gear means you have to buy an entire OEM diff.
Old Dec 10, 2002 | 08:52 AM
BROOD's Avatar
Tim,
I'm going with the other guys in that the speedo gear was not installed. You can pull the VSS sensor out of the trans and look inside. You should be able to see/feel the helical gear on the diff housing. If you wish I can help you check it out.
Breaking that gear sucks....like Ralphie said you can't buy it separate of the housing. Be careful
[Modified by SLPR, 10:05 AM 12/10/2002]
Old Dec 10, 2002 | 09:04 AM
Nameless RB26's Avatar
Default Re: No speedometer after Quaife install?? (SLPR)
OT - Why are you heating that? Are you taking the spedo off? I would guess that metal expands when it's heated..
Old Dec 10, 2002 | 09:09 AM
BROOD's Avatar
Default Re: No speedometer after Quaife install?? (Nameless)
Heat = thermal expansion
I use a small pulley puller to remove the gear always worked fine for me without heat. I install by heating the gear in the oven and putting the diff in the freezer. It installs fairly well after that....I still use a little machine pressure to make sure the gear is fully seated though.
Old Dec 10, 2002 | 09:18 AM
NVMYSi's Avatar
SLPR,
Thanks for the help. I will contact you when I get the trans out, I may need you help on this one.
Old Dec 10, 2002 | 09:45 AM
Kataku2K3's Avatar
Quaife ='s Awesome aftermarket LSD.... I like them way better then the Helical OE type.
Old Dec 10, 2002 | 09:49 PM
Arturbo's Avatar
Better than steak
25 Year Member
I was heating the gear up to pull it off. Notice I was heating the gear itself, and not the shaft itself. I was easy to pull it off, the put it on the quaife right after before it cools. If you have access to a press, then you dont need to do this.
To the original problem, if you still have your OEM diff then see if the gear is on there. And like the previous poster said, do NOT damage because you cant buy that gear by itself. You have to buy the entire diff which is very expensive.
art
Old Dec 10, 2002 | 09:53 PM
since we're on the topic here ~
when you install the LSD, is there anything special you need to do besides for swap over the ring gear, spedo, bearings? I've heard you need to "preload" it or something, which is what my honda mechanic said. I'm going to be replacing mine, and my helms manual is on the way..
can someone explain the preloading process?
Old Dec 11, 2002 | 02:45 AM
Arturbo's Avatar
Better than steak
25 Year Member
Maybe this thread might help. There are some links in it that might help.
https://honda-tech.com/zerothread?id=321482
art
Old Dec 11, 2002 | 07:47 AM
TheHater
Guest
Posts: n/a
Damn yall do that yourselves im hella scared messing with the trans and internals. Well I guess errbody starts off somewhere.
Old Dec 11, 2002 | 07:51 AM
BROOD's Avatar
Default Re: No speedometer after Quaife install?? (BOOSTINSI)
Don't be scared...you have to learn somehow.
Old Dec 11, 2002 | 07:54 AM
92sleepR's Avatar
New User
unbolt the VSS and see if its engaging properly with the ring gear. Its entirely possible that whoever installed your dif screwed something up or maybe didn't swap the speed sensor gear over to the Quaife (in which case he's a real bonehead and you should make him do it right)
P.S. Yeah, what everyone above said
Mike
[Modified by 92sleepR, 4:55 PM 12/11/2002]
TheHater
Guest
Posts: n/a
Yup...Im gonna start doing my turbo install in mid december by myself. Thats no internal crap but its a start.
Old Dec 11, 2002 | 08:16 AM
Farnsrocket's Avatar
Man, that reminds me, when I did my Quaife, I was pulling my gear off with a 3 arm puller and one of the arms was not on right and as I tightened the puller with a wrench, I heard this crunch, look down and the one arm chipped the gear!!!!!!!!! It was just a small piece and it looked like it would not affect the gear overall. So I changed the puller to a two arm puller and the gear come off without a problem. It worked fine when I got the car back together. Scared the hell out of me.
Old Dec 11, 2002 | 08:52 AM
NVMYSi's Avatar
Default Re: No speedometer after Quaife install?? (92sleepR)
Mike
Well, yes the problem is that the speedo gear was not taken off the stock diff and put on the Quaife, very frusterating....the person who installed it was not a incompetent just having a off day I guess. On the positive side, its winter in IL and what else did I have to do.....time to fix it
si.life.108
Aug 14, 2014 03:55 PM
aziaticvang
Jan 13, 2008 06:35 PM
FGride
Feb 18, 2006 09:37 AM
Lucky_Smurf
Apr 20, 2005 12:22 PM
951dc5
Feb 13, 2005 10:48 AM
