Recall for 94-97
Old Dec 9, 2002 | 05:57 PM
UseR's Avatar
Default Recall for 94-97
What recalls are on the years 94-97?? I understand that there is an oil leak for these years, is this true? Also, tell me any other recalls, thanks.
Old Dec 9, 2002 | 06:05 PM
Razor's Avatar
Default Re: Recall for 94-97 (UseR)
yep, it was the balancer shaft oil seal recall...they just install a clip over it to prevent the seal from backing out. the other one i can think of is the a/c recall where there was a problem with one of the a/c wires shorting out and might cause a fire. also, for 96 or 97 or newer accords, there was an ignition recall.
Old Dec 9, 2002 | 07:31 PM
UseR's Avatar
Default Re: Recall for 94-97 (Razor)
well what about all these:
98-011 AUG 01 Keyless Entry - Transmitter
01-070 AUG 01 M/T - 5th Gear Grinds On Upshift
00-099 DEC 00 Wiring Terminal - Repair Instructions
00-089 OCT 00 Supplemental Restraint System - Inspection
99-018 APR 00 Required Special Tools And Equipment,
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-015 MAR 00 Audio Unit with CD Player/Changer - Error Codes
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
97-015 DEC 99 Service Publications - Availability & Ordering
99-061 JUL 99 Ball Joint Removal and Installation Tools
99-037 MAY 99 Front Balancer Shaft Oil Seal Installation Tool
99-030 MAY 99 Recommended Materials
19_1-04 OCT 98 Interior - KRYTOX(R) Fluid Applications
98-058 AUG 98 Radio - Poor Reception/Static on AM Band
98-051 AUG 98 Special Tool Loan Program
98-042 MAY 98 Engine Block - Oil Seepage
98-026 APR 98 Audio Unit - Antitheft Code Labels
98-018 APR 98 CV Joint Boot - Band Tool
98-023 MAR 98 Power Steering Pump - Fluid Leak
98-001 FEB 98 Engine/Transmission - Hydraulic Lift Truck usage
97-060 SEP 97 Windows - Front Door Glass Comes Out of Run Channel
95-057 AUG 97 M/T - Fifth Gear Grinds During Upshift.
97-031 AUG 97 A/C - Does Not Blow Cold Air
90-007 MAY 97 90-007 - 05/27/97
86-020 MAY 97 Brakes - Disc Refinishing Procedure
97-027 MAY 97 Tools - Denso HLD-100 Halogen Leak Detector
97-016 APR 97 Seats - Manual Seats Hard to Adjust
97-028 MAR 97 Body - Minor Paint Finish Repair
97-018 MAR 97 Suspension - Rear Wheel Bearing Noise
97-020 MAR 97 Tools - New Fuel Pressure Gauge and Replacement Parts
97-011 FEB 97 Interior - Cracking Noise From the Door Armrest
94-029 NOV 96 Brakes - Fluid Leak (ABS Accumulator)
96-050 NOV 96 Brakes - Fluid Leak from the ABS Modulator
96-055 OCT 96 Clutch - Judder at Cold Start
96-046 OCT 96 Keyless Entry - Transmitter Programming Information
96042 SEP 96 Tools - Power Steering Pressure Gauge
96031 JUN 96 Antitheft System - Transmitter Does Not Work
93033 JUN 96 Seat Belt - Tongue Stopper Button Broken
94041 MAY 96 Exhaust - System Buzz
96002 MAY 96 Interior - Center Armrest Appears Worn
89029 MAY 96 Radio - Warranty Exchange/Out Of Warranty Repair
89004 MAY 96 Required Special Tools & Equipment
96001 MAR 96 Interior - Armrest Fabric Worn
96012 MAR 96 A/C - System Performance Test
95025 MAR 96 Clutch - Creaking Pedal
96014 FEB 96 Tools - Belt Tension Gauge Calibration and Repair
91030 JAN 96 Seat Belt - Slow to Retract
92012 JAN 96 Seat Belts - Warranty Replacement Policy
95057 DEC 95 M/T - Grinds During Upshift
89029 DEC 95 Radio - Unit Diagnosis
95050 DEC 95 Lighting - Courtesy Light Lens Missing
94041 NOV 95 Exhaust - Buzzing At 1800 RPM
93049 OCT 95 Interior - Instrument Panel Creak
95041 OCT 95 Windows - Screeching Noise when Lowering Drivers Window
94024 OCT 95 Windows - Clunk Noise from the Door Glass
95040 OCT 95 Windows - Front Window Comes Out of the Channel
95036 OCT 95 Suspension - Front End Squeaks
95034 SEP 95 Body - Loose B-Pillar Seal
90007 AUG 95 Service Publications and Supplies
95024 JUL 95 Airbag - Cable Reel Holding Fixture
95025 MAY 95 Clutch - Creaking From the Pedal
93041 APR 95 Door - Damaged Handle Seal
89029 MAR 95 Radio - Unit Exchange/Repair
95018 MAR 95 Heater - Control Indicators Do Not Light
94039 MAR 95 Interior - Buzzing From Shoulder Belt Anchor
95017 MAR 95 Brakes - Replacement Rear Pads
95013 FEB 95 Instruments - Fuel Gauge Does Not Read Full
95011 FEB 95 Heater - Blower Motor Noise
95008 JAN 95 Cellular Phone - Out-of-Warranty Repair Information
93038 JAN 95 Brakes - ABS Light Comes ON
95003 JAN 95 Body - Buzzing In the B Pillar
95001 JAN 95 Doors - Inside Front Handle Buzz
95002 JAN 95 Interior - Squeak From The Door Panel
ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
94040 NOV 94 Interior - Buzzing From The Rear Shelf
93037 NOV 94 A/C - Unsatisfactory Performance
94038 NOV 94 Body - Trunk Difficult To Close
94034 OCT 94 Body - Roof Rack End Covers Fall Off
94029 OCT 94 Brakes - Fluid Leak
94032 OCT 94 Interior - Tonneau Cover Creaks
90014 SEP 94 A/T - Remanufacturing Exchange Program
94028 SEP 94 Body - Wind Noise at the Front of the Door
94027 SEP 94 Body - Wind Whistle At The A Pillar
94025 AUG 94 Steering - Wheel Oscillates or Has a Shimmy
88012 AUG 94 Tools - Exacta Code Key Cutter
94020 JUL 94 Body - Fuel Fill Door Doesn't Open
94021 JUL 94 Instruments - Temperature Gauge Always Reads Hot
94019 JUN 94 Door Locks - Cycle From Unlocked To Locked
94017 JUN 94 Seats - Noise from The Drivers Side Track
94014 MAY 94 Cellular Phone - Troubleshooting
94004 MAR 94 Brakes - Parking Brake Does Not Release Fully
94001 FEB 94 Mirrors - Wind Noise Through Door
93045 FEB 94 Instruments - Trunk Open Indicator Stays On
91008 JAN 94 Lighting - Buzzing During Turn Signal Lever Operation
88023 DEC 93 Battery - Testing Procedure
93050 DEC 93 Doors - Weatherstrip Out of Position
93047 NOV 93 Moonroof - Wind Deflector Rattles
93046 OCT 93 Mirrors - Rearview Mirror Tension Adjustment
93043 OCT 93 PDI - Reposition the Lift Motor Wiring Harness
93044 OCT 93 PDI - Reset Maintenance Required Indicator
93042 OCT 93 Mirrors - Wind Noise At The Door Mirror
93036 OCT 93 Body - Paint Codes
93039 OCT 93 Windows - Water Leaking From The Tops Of The Doors
ATRATB191 OCT 93 A/T - Failsafe Modes
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
ATRATB8930 OCT 89 A/T - Math Part II
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Whats all this?
Old Dec 9, 2002 | 07:35 PM
ArchAngel Sabastian's Avatar
New User
" owner link" @ honda.com doesnt list the oil seal recall...?
Old Dec 9, 2002 | 07:48 PM
TypeSH's Avatar
Default Re: Recall for 94-97 (ArchAngel Sabastian)
all of those are probably Technical Service Bulletins, not recalls. Unless you still have warranty (which is long gone for most), they arent required to cover the repairs for free. The Balancer shaft seal was the main recall, and the AC one i think is for 95's?
Old Dec 9, 2002 | 07:51 PM
Razor's Avatar
Whats all this?
these aren't recalls mang
Old Dec 9, 2002 | 07:55 PM
UseR's Avatar
Thanks guys
Old Dec 9, 2002 | 08:06 PM
Razor's Avatar
yeah just make sure the balancer shaft seal is taken care of first, u dont want a burnt out motor.
Old Dec 9, 2002 | 08:25 PM
RotaryBzzz's Avatar
You better move fast. I've read that the "free repair" part of that recall is going to expire Jan 1, 2003.
I had mine done a couple months ago. Took about an hour at the dealer...wasn't major
Old Dec 9, 2002 | 10:00 PM
roydogg's Avatar
Default Re: Recall for 94-97 (RotaryBzzz)
Make sure you get the ignition coil fixed cause my wife was driving over some railroad tracks and the switch decided to cut off causing the car to die and lock the wheels. Lucky no train was coming my kids were in the car too . Had my attorney which is my daughters godfather call honda corporate in Cali and had him get everything paid for free buy honda and a verbal apology from someone in there.They also did the oil thing too.
Old Dec 10, 2002 | 03:30 AM
TouringAccord's Avatar
H-T Order of Merit
Can I purchase the clip that they put on the balancer shaft seal and do it myself? The only reason I ask is cause I can't drive my car till I get it fixed and I don't know if I can get it into the dealer before the due date. Worst case scenario, what will it cost me to take it to the dealer once I have my car going again, assuming it's after Jan 1?
Old Dec 10, 2002 | 05:09 AM
Nick M's Avatar
Default Re: Recall for 94-97 (TouringAccord)
I did the balancer shaft oil seal recall on my H22a before I put it into my Accord (it applies to H22a's as well) Its very quick and easy to do while out of the car obviously. But even if its still in the bay, its very quick. It is worth the peace of mind. Have it done before Jan 1st.
Old Dec 10, 2002 | 05:15 AM
H-T Order of Merit
Default Re: Recall for 94-97 (Nick M)
ok, so are you saying I can buy the part and do it myself if I can't get it in before Jan 1. If I can, do you know about how the part costs? Thanks.
Old Dec 10, 2002 | 05:58 AM
Hippie's Avatar
I got one for $5.50 at my local dealer, 4th Gens have the same problem ( I found out the hard way ) but aren't covered under the recall.
Old Dec 10, 2002 | 06:00 AM
H-T Order of Merit
Default Re: Recall for 94-97 (Hippie)
Thanks
Old Dec 10, 2002 | 06:01 AM
Desslok's Avatar
[hijack]
Hey Hippie,
How many miles on your 4th gen, I got about 135,xxx and was woindering if I should expect mine to go out soon, thanks.
[/hijack]
Old Dec 10, 2002 | 06:23 AM
adkinsca's Avatar
I have had a '94 since new, and the only recall notice we have ever gotten is for the balancer shaft oil seal that has been described in this thread.
Old Dec 10, 2002 | 06:28 AM
UseR's Avatar
Default Re: Recall for 94-97 (roydogg)
WHOA...he literally had honda blow him and swallow...maybe I can do that today, because right now im at school...(lame finals) afterwards im taking to the local dealer to have it fixed. Thanks alot, and thanks to you who told me about the deadline. (Thank God it happened NOW and not later)
Old Dec 10, 2002 | 08:10 AM
Hippie's Avatar
Default Re: Recall for 94-97 (sp)
[hijack]
Hey Hippie,
[/hijack]
Put new timing belts on at about 191K and got the retainer then but the instructions with it were so damn small I couldn't see what bolt it was suppose to go on. I tried everyone I could find and nothing worked. Since the seal looked good and showed no signs of being unseated I put it all back together. BIG MISTAKE ! The seal popped out just past 193K. This time in the course of cleaning off the oil all over the motor I uncovered a bolt just outside the timing cover near the retaining bolt for the dipstick tube., THAT is where the retainer is attached. You have to pull the timing covers to get the retainer in there, it was almost as much trouble as doing the timing belts. Wish the instruction sheet had been printed so you didn't need a microscope to read it.
Old Dec 10, 2002 | 07:14 PM
UseR's Avatar
About those service bulletins, does anyone know how much it would cost to fix those problems, because 95% of those bulletins apply directly to my car.
Slow CX
Audio / Security / Video
Feb 27, 2003 07:48 PM
danny
Dec 4, 2001 05:37 PM
