lexan windows?
Old Dec 9, 2002 | 04:42 PM
OldSchoolCrxSiR's Avatar
Default lexan windows?
where can i get some lexan or who do i talk to to get lexan back windows and hatch window made for my 87 crx?
Old Dec 9, 2002 | 05:05 PM
cr-x si's Avatar
Default Re: lexan windows? (OldSchoolCrxSiR)
I work at a glass shop in ohio, and we do auto glass too. Im sure if you found a place like that were you live they could do it too. Basicly what we do is take out the window you want to replace w/ lexan. And make a pattern, then we just cut down the lexan to fit the car and urithan it in. It is about a about a 6-7 hour job (car has to sit for 3 hours to dry) if you take you time. The price of the lexan would be about $100-150 then you would have to add i labor. You could probly find a place in the yellow pages if you look. Anyplace that sells plexi or glass will probly carrie lexan. If not they can most likley order it for you
Old Dec 9, 2002 | 05:56 PM
Broken Gearbox's Avatar
Default Re: lexan windows? (cr-x si)
http://www.optauto.com/webstore/prod...k=yes&dept=854
Theres a link that has them...its for the back half for a CRX. Its a little pricey but i would get it if i was gonna make a full-race car but if its your daily driver dont waste your money.
**Oh ****...my bad...i forgot that the 87 CRX's are different ...i guess your gonna have to find a place that does it..and have them customize it.. **
[Modified by dEF juNKie, 6:57 PM 12/9/2002]
Old Dec 9, 2002 | 06:10 PM
FourthGenHatch's Avatar
Default Re: lexan windows? (dEF juNKie)
Do they make them just for the rear side windows now? I know they always had side windows and rear window, but I would assume removing the rear glass means no defroster which won't work for me. Are these just the 2 side pieces?
[Modified by FourthGenHatch, 3:11 AM 12/10/2002]
Old Dec 9, 2002 | 08:08 PM
Pelican's Avatar
Default Re: lexan windows? (FourthGenHatch)
Get the BEST quality Lexan from Home Depot. $60 dollars a sheet and you'll need two. Hardest part is taking the windows out of you don't have the right tool. Just take them out and use it as a template. Drill your holes and rivet them in.
But really, don't do it unless its gonna be full race. Not worth it.
drmix
Dec 17, 2007 10:51 PM
killahkosha
Northwest (Sales)
Jan 20, 2007 09:06 PM
Supahatch
44
Apr 13, 2006 06:18 PM
chex329
Sep 2, 2005 06:35 PM
LOWLIFEHATCH
Aug 20, 2002 07:25 AM
