F22 and H22
Old Dec 9, 2002 | 04:19 PM
1 2 NV's Avatar
Default F22 and H22
usually i dont post stupid topics like this. but thumbing through the prelude service manual, whats the difference between the H22 and F22 blocks???? i mean physically they look the same. internally i know the H22 is stronger but anyone know specific differences??? just curious and thought id post.
Old Dec 9, 2002 | 05:28 PM
Cow's Avatar
Cow
Default Re: F22 and H22 (hondaatwsu)
The F22 is SOHC, the H22 is DOHC. Other than that I don't know.
Oh yeah, H22 has veeteck. Haha.
[Modified by Cow, 9:29 PM 12/9/2002]
Old Dec 9, 2002 | 07:56 PM
1 2 NV's Avatar
Default Re: F22 and H22 (Cow)
y did u even answer. that was a total waste of a post.
Old Dec 9, 2002 | 08:34 PM
Shawn C's Avatar
In The Garage
the h-series and f-series are very similar, its really just that the f22 and f23 are setup to bolt to a sohc head, and the h22 and h23 are setup for a dohc head. i know this cause i used to want to put an h22 head on my accords old f22 block, but it just wouldnt line up. oh well. thats why i got the teg
Old Dec 9, 2002 | 08:50 PM
Cow's Avatar
Cow
Default Re: F22 and H22 (22lbGS-R)
Ask a stupid question, get a stupid answer..
Old Dec 9, 2002 | 09:07 PM
1 2 NV's Avatar
thanx for the insight. like i said in the first post the blocks have alot of similarities but i wanted insight to what the differences actually were. what didnt line up??? bolt holes for the head i presume.
Old Dec 10, 2002 | 07:41 AM
Shawn C's Avatar
In The Garage
i honestly couldnt tell you if the head bolt holes line up or not, i cant remember... but if you compare the head gaskets of the 2 engines, youll totally see what im talking about. the passages dont line up. thats how i compare compatability between engines, i guess. it makes sense, you know?
Old Dec 10, 2002 | 03:49 PM
1 2 NV's Avatar
yeah i hear what ur saying. i know the heads arent compatible but just by the looks of the block they are really really close. ****, if the blocks were interchangable everyone would have a DOHC F22, haha.
Old Dec 11, 2002 | 05:51 AM
Ryu's Avatar
Ryu
i went to my local import junkyard and saw my first DOHC F22B block
Old Dec 11, 2002 | 06:00 AM
satan_srv's Avatar
Default Re: F22 and H22 (Ryu)
F22 bore = 85mm
H22 bore = 87mm
Old Dec 11, 2002 | 03:04 PM
JPX's Avatar
JPX
H22 is avariant of the f22a1 from 90-93 SOHC.
Both blocks actually have the same physical strength.. good up to 320hp
Oil drain holes are different on the h22 nad larger...
Im building a f22race motor for next year..with over +300 hp..
They say it can't be done( all motor)...we will see...
Old Dec 11, 2002 | 03:32 PM
1 2 NV's Avatar
Default Re: F22 and H22 (JPX)
anymore info that u know of???? all this info is good stuff. although i thought htey had the same bore. if not that makes the F22 have a longer stroke than the H22. both 2.2L
Old Dec 11, 2002 | 06:15 PM
79 civic's Avatar
thats why you put the F22 crank into an H22 giving i think 2.4 or 2.5 liters
Old Dec 11, 2002 | 06:34 PM
KStuned's Avatar
Default Re: F22 and H22 (79 civic)
So does the f22 crank bolt into the h22 block?
I have 2 blown up f22's and a torn down h23 right now, I might have to see what works!
I know the crank between the h23 and h22 are interchangeable, I doubt the f22 crank works, but I just might see if the f22 crank will set in the h23 block. hmmm.
Old Dec 11, 2002 | 06:54 PM
satan_srv's Avatar
Um your math ain't so good.
The F22a crank is 95mm, and in an H22a would displace 2.258L same as the H23. The cranks are likely the same. H23 and F22a
Old Dec 11, 2002 | 08:39 PM
GZERO's Avatar
Default Re: F22 and H22 (satan_srv)
this is a VERY good questions, but i don't think anyone have a good answer, it would be cool if we could get pics of the F22 and the H22 stipped and all that, i always wanted to know the real difference between the H22 and the F22 block, no one has ever been able to tell me.
consider this post as a BUMP
Old Dec 11, 2002 | 08:46 PM
1 2 NV's Avatar
Default Re: F22 and H22 (GZERO)
well my best friend has a stripped H22 block and i have his old F22 block so this weekend, i might b able to get pics of both for reference. thans for the bump.
HaOcNcDoArd96
Jun 3, 2005 10:41 AM
StraightCivic
Apr 30, 2005 09:54 PM
preludechick
Oct 3, 2003 03:09 PM
mattking93vtec
Jan 12, 2003 10:30 AM
