boosting in progress, some questions.
I have a 90 lude si with b20a engine. I am bossting it, block is currently at GE getting built. I was just wondering what material I should use to make my own header. I have brother in-law who is a professional welder so its going to be done right. I got the header flange, turbo flang and wastegate flage, I just want to know what to use for the runners. Also, I was wondering what size IC pipe to use. Any suggestions would be great. Thanks alot.
When welding stuff that's going to be subjected to a lot of heat you want to use metals of very similar alloying content. IE stainless with stainless. IC piping should match the IC's tubing diameter.
Thanks for your input. Dose anyone else have any ideas of what material I should use for the runners on the header or where to get it? Thanks guys.
I think your best bet would be to purchase weld els from http://www.mcmaster.com. You can get them in mild and stainless steel.
Is their anyway you could give me a direct link to the specific page on there that I need to look at? I am having a hard time finding them. Thank you for your help.
http://www.mcmaster.com/param/asp/ps...+Pipe+Fittings
That link is for steel weld els. If it doesn't work just search for "weld els" on their site.
