90-91 integra fuel pump, calipers, & master cylinder on 90-91 Si
are they completely compatable? Anyone swap these parts on to their cr-x instead of the stock counterparts?
Fuel pump is the same, not sure about specs but willing to guess also the same, rear brakes will bolt up on CR-X SI seeing it has same rear discs or you can bolt the entire rear traling arm on 88-91 civic or DX, the front calipers will not bolt up unless you use the integra front spindle or 90-91 EX, tried to make it work and there is no way, now the mater cylinder you would have to get the lines from the proporting valve to the master cyclinder, but can be done.
HT Chaplain
14
Aug 14, 2003 08:20 PM
silverkorn
24
Jul 31, 2003 09:02 AM
Torino91LS
12
Mar 14, 2003 01:54 PM
