flashing engine check light
Old Dec 9, 2002 | 12:06 PM
katie's Avatar
Default flashing engine check light
the engine check light on my 98 accord keeps flashing, how do i decipher the code?
Old Dec 9, 2002 | 12:18 PM
Desslok's Avatar
Default Re: flashing engine check light (katie)
Try the search feature, you will find more, but here is a start:
https://honda-tech.com/zerothread?id=353430
Old Dec 9, 2002 | 12:40 PM
Razor's Avatar
u might need a PGM reader thingy, i don't know how obd2 cars work...for my car all i do is just jump the ECU and look for the flashing LED.
Old Dec 9, 2002 | 01:21 PM
Stew Pidasso's Avatar
Default Re: flashing engine check light (Razor)
You have to connect pins 8 and 13 on the data link connector under the drivers side dash. I tried to do an ASCII drawing of the diagram the 2 X's are the pins that you need to connect. After connecting these pins you need to turn the ignition to the on position without the engine running and watch the Check engine light and see how it flashes. Long Flashes are 10's places and short flashes are 1's places. I.E. 4 long flashes and 2 short flashes = the code 42. It will flash all engine codes that are in memory and then it will repeat them. Check them for accuracy and then come back on here and IM me on h-t or reply to this thread and I will look up the codes for you.
|__\
|_|_|
|_|_|_
|_|_| |
|_|_| |
|X|_| |
|_|_|_|
|_|_|
|_|X|
Borrowed from an earlier post by CmptchAV6
Old Dec 9, 2002 | 01:49 PM
briq4's Avatar
Hmmm is it the check engine light or the maintenance light? I have never seen the check engine light flash only come on and stay on.
Old Dec 9, 2002 | 06:32 PM
jweller's Avatar
Default Re: flashing engine check light (briq4)
I'm getting this tattooed on my forehead.
http://mywebpages.comcast.net/jweller1/check_eng.html
[Modified by jweller, 10:34 PM 12/9/2002]
Old Dec 9, 2002 | 06:44 PM
niedejb's Avatar
Default Re: flashing engine check light (jweller)
Your forehead must be huge.
Solidis
Apr 8, 2013 04:33 PM
cennouu
Jan 12, 2011 07:49 PM
jeremy.
Aug 22, 2003 06:59 AM
wm5holla
Mar 15, 2003 12:40 PM
Slow
Nov 20, 2002 11:11 PM
