Brake Calipers, can someone help me?
I have a 93 si hatch, the rear calipers are sticking and need to be replaced. I've taken them apart before and cleaned the pistons and seals, this sovled the problem for a little while. They do not make a rebuild kit for the rear calipers that you can buy. If they did i would have done this long ago. I researched this a little a while back on what integra calipers would bolt up to my hubs and I thing they were 94-96 integra RS calipers. If you know anything about it please let me know.
PS: If you are selling rear disk conversion cheap let me know.
All gen3 integra rear calipers are the same and will fit, this is not just a USDM problem, it happens on my JDM integra and all my friends UKDM civics/crx/integras, sorry i havent found a way to cure it, i just replaced my integra rear calipers a while back with a set of 98 UKDM civic VTi rear calipers that i got for $30 from a breakers yard
Are the calipers seized? It happened to me before, the kit was more expensive then a slightly used nissin rears, but that was for my prelude. Go to a junk yeard. They will come with pads, just find some with little wear.
mazdabish
Suspension & Brakes
10
Jun 19, 2014 06:48 AM
mantic6t9
14
Dec 11, 2002 09:37 PM
mantic6t9
Dec 9, 2002 01:49 PM
