Tial 35mm Wastegate
I'm not to fimiliar with wastegate settings. I was wondering is there a way for this wastegate to read as low as 5 psi and as much as 20 psi with an AVC-R boost controller?
The .35 bar spring will get you your low boost setting, but as far as 20psi i wouldn't recomend doing that with the same wasegate via a boost controller.I believe once you rech 15psi or so you want to move up to the next wastegate 40mm.
