DX harness
Old Dec 9, 2002 | 04:41 AM
Dancing is Forbidden's Avatar
Default DX harness
Does anyone make a harness for a DX->B16a? I dont want a whole new harness but just want something with the wires for the MPFI swap and then the wires for VTEC. I know HASport has one for $250 but I dont want to pull my entire harness, something more like a jumper I suppose. Thanks guys.
Old Dec 9, 2002 | 05:15 AM
Hondasaurs's Avatar
Default Re: DX harness (EF9_SiR)
Its easy to use your DX harness. All you have to do is put the DX harness on the B16 engine and run 4 or 5 wires to the ECU. I did the wiring for my MPFI swap in about an hour. If you do your own without an aftermarket wire harness, I'd suggest soldering all of you connections.
Old Dec 9, 2002 | 05:30 AM
Default Re: DX harness (ZC_CRX)
Where did you get the connectors? Did you just use the ones that came with your engine? Thanks.
Old Dec 9, 2002 | 05:45 AM
Hondasaurs's Avatar
I have an 89 CRX Si that I'm using for a parts car right now or until I decide what I want to do with it. I took the Injector resistor box from it. I also used pins from the wire harness that goes to the ECU in the CRX. Two wires from the ECU go the the Fuel injectors and the remaining two wires on the Fuel injector wires (I beleive a yellow and a red wire if I'm not mistaken) go to the DX harness. Then the remaining two yellow/black wires onthe DX harness go to the Injector Resistor box. Its an easy swap, if you decide to do it this way message me or email me, I'd be more than happy to help.
S2k@9K
17
Aug 20, 2018 04:14 PM
mike93eh2
Apr 23, 2008 06:13 PM
crexer
Dec 27, 2004 07:10 PM
johnzm
May 31, 2004 11:49 AM
highmilehatch
Aug 8, 2003 04:05 AM
