1992-1993 GS-R Wiring Harness replacing 1988 CRX Si Harness?
it's possiable if you change the plugs because the plugs on the b16a is different atleast the first gen b16a
your car is non-obd, the 92-93 b17 is obd1. it wont plug right up. you will need an si harness from any 88-91 civic or crex.
the ecu you need is either a pwo or a PR3. if you use the Si/DX(the dx harness will have to be rewired like an Si) harness those ecu's will plug right in. You can use the GS-R ecu but you would have to rewire the entire car to be OBD 1. Very bad and timely idea. Sell the ecu and get the one for you setup.
[Modified by Cory man, 8:04 PM 4/29/2001]
Sosa0311
Sep 15, 2012 11:14 AM
exist12
Oct 26, 2007 08:19 AM
june
Nov 30, 2001 06:49 PM
