e what octane?
Old Dec 8, 2002 | 06:57 PM
TheBestCRX's Avatar
Default what octane?
i was just wondering what octane gasoline should be used in all B series motors?
[Modified by civic89dx, 3:58 AM 12/9/2002]
Old Dec 8, 2002 | 06:59 PM
TheBestCRX's Avatar
Default Re: what octane? (civic89dx)
don't worry about the e in the title. sorry.
Old Dec 8, 2002 | 07:00 PM
MADEINIRAQ's Avatar
premium for b16
not sure about b18a.. probably regular unleaded.
this is on stock motors of course
Old Dec 9, 2002 | 04:35 PM
StorminMatt's Avatar
It depends on the B-motor. Low compression B-motors (B20B, B18A, B18B) run fine on regular unleaded (87 octane). This is what Honda recommends. The B20Z, on the other hand, has a higher compression ratio than other non-VTEC B-motors (9.6:1). It is also knock sensor equipped. And keep in mind that while Honda recommends regular unleaded, Civic swappers use Integra ECUs to run these motors. The Integra ECU has less than optimal fuel maps AND does not read the knock sensor. So if you have this motor, you probably want to run midgrade (89 octane). I do. Premium fuel (91+ octane) is recommended for ALL DOHC VTEC B-series motors.
Old Dec 9, 2002 | 04:45 PM
89 CRX SI's Avatar
Default Re: what octane? (StorminMatt)
Well up here in the okanagan I use 94 octane because it is the only gas that is brought in by a truck from a safge source. The rest of it is piped in from a nearby station. This pipe gets gas then diesle pumped throught the same one like gas for a day then diesle then gas again which really screws up everything. They dont flush it before they change mixtures so you fuel pump will go kaaaaplut obver time.
SoFresh1189
Jan 26, 2010 02:32 PM
4 door beast
May 9, 2009 02:46 PM
kahriak
Acura TSX
Feb 10, 2008 12:45 PM
teg your it
Apr 23, 2005 02:06 PM
gsrvx
Nov 9, 2002 11:04 AM
