HX rims on my 96 EX
Old Dec 8, 2002 | 06:27 PM
StevenTran305's Avatar
Default HX rims on my 96 EX
Wassup, I juss picked up a set of HX rims today and I know for sure they will not fit on my EX, so my question is how much do I need to sand off the Calipers? A lot or a little? Thanks
Old Dec 8, 2002 | 06:46 PM
Paranoid Android's Avatar
Default Re: HX rims on my 96 EX (StevenTran305)
wtf do those look like? everyone is stoked when they get them....
i never seen them before...er...never knew it if i did.
Old Dec 8, 2002 | 07:25 PM
OE Tuner's Avatar
Default Re: HX rims on my 96 EX (Paranoid Android)
Dude what are you taking about? HX wheels will bolt right up to an EX. VX wheels will not fit, but for sure HX wheels will fix.
Old Dec 8, 2002 | 07:29 PM
pervytheclown's Avatar
I wouldnt think you'd have to sand anything...how big are your calipers?
Old Dec 8, 2002 | 08:33 PM
Timmayeg's Avatar
New User
Default Re: HX rims on my 96 EX (pervytheclown)
HX wheels do not fit right on a EX without spacers or grinding the brake down, not much is needed to grind. spacers would be safer
Old Dec 8, 2002 | 08:51 PM
Default Re: HX rims on my 96 EX (OE Tuner)
No, they don't. Thanks 91_EF_Civic for clearing things up. Thanks for ur replies.
Old Dec 8, 2002 | 08:55 PM
Timmayeg's Avatar
New User
i went through the same deal hx on my old 94 EX, i grinded the **** out of the brakes
Old Dec 13, 2002 | 09:35 PM
OE Tuner's Avatar
Default Re: HX rims on my 96 EX (91_EF_Civic)
I digress. I expected that the HX wheels being 14inchers would bolt right onto an EX, since it also comes standard with 14 inch wheels. My understanding was that the brakes were essentially the same also. I guess I was mistaken.
Old Dec 13, 2002 | 10:39 PM
GCEX's Avatar
Alright, let's get some knowledge into this thread. I want to get a set of HX rims also. I'm guessing there are no clearance issues for the rear since it's drum brakes. Are spacers easily purchased? How much for two that are big enough to clear the HX rims over EX brakes calipers? Do they just slip on, so you can easily take them off if you're swapping rims?
Old Dec 13, 2002 | 10:54 PM
General Kills's Avatar
Default Re: HX rims on my 96 EX (GCEX)
Its a funny thing. I was just thinking about this the other day when rims came into mind for the car I'm getting. They are small, light and are made by honda. Are they really that much better/lighter than the stock ones with the caps?
Old Dec 13, 2002 | 10:58 PM
Daniel's Avatar
Default Re: HX rims on my 96 EX (Tunerdude)
wheelweight.net says. . . .
OEM 14" blackies = 18 lbs. a piece
OEM HX rims = 11.75 lbs a piece
Old Dec 14, 2002 | 09:37 AM
Default Re: HX rims on my 96 EX (Daniel)
Wow they are heavier than I thought.
Old Dec 14, 2002 | 09:55 AM
VTC_CiViC's Avatar
I made the same mistake, learned the hard way when my car didn't want t roll anywhere
Spacers or grind the edge of the caliper down a little.
DSMAddicted
16
Sep 3, 2010 05:10 PM
NerveAgent
Jan 14, 2007 12:13 PM
7mile
Sep 4, 2006 01:25 PM
MyWhiteCivic
Jan 20, 2003 06:19 PM
Cat
Aug 28, 2002 12:39 AM
