Vibration at idle
Old Dec 8, 2002 | 01:52 PM
MVK's Avatar
MVK
Default Vibration at idle
I have a 1988 Honda Accord Lxi. I had some steering wheel vibration at idle esp when in drive. I was told by friends to change the motor mount. So I replaced both front and rear motor mount( The old one looks good though) Now the vibration got worst and car shakes violently at idle in drive. A little gas and vibes go away. What could this be?
Also recently noticed something strange. When all electric things are on like head lights, coolig fan, blower and if I press on brake lights or try to lock the door, the idle speed drops by about 100 to 150 rpm and the car shakes violently.
The car runs like a charm when its at 10 mph or more.
I am confused. Please help
MVK
Old Dec 8, 2002 | 02:46 PM
Desslok's Avatar
Default Re: Vibration at idle (MVK)
Check your idle. An easy ghetto way to fix is to bump yur idle speed up until it stops.
Old Dec 8, 2002 | 02:54 PM
MVK's Avatar
MVK
Default Re: Vibration at idle (sp)
Thanks for a prompt reply. Well I did increase the idle spped a bit but I still get quite a bit of vibes. Also The drop in idle speed under electrical load is annoying. Any thoughts. Please I am really desperate. I just spent about 1200 bucks on this car. Everything else is so good even at 148k miles.
Thanks again.
MVK
Old Jan 6, 2005 | 09:52 PM
Shehzada's Avatar
Clean your TB and it will solve ur problem.
Old Jan 7, 2005 | 07:35 AM
ZexyAccord's Avatar
Default Re: Vibration at idle (Shehzada)
My car does the same thing... how do you clean your Throttle Body? and also? would a ground wire kit stop the idle drops when door locks and head lights etc... are activated.
Old Jan 7, 2005 | 08:21 AM
Filthy Focker!'s Avatar
Default Re: Vibration at idle (ZexyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord &raquo;</TD></TR><TR><TD CLASS="quote">My car does the same thing... how do you clean your Throttle Body? and also? would a ground wire kit stop the idle drops when door locks and head lights etc... are activated.</TD></TR></TABLE>
DOn't post *****.
ANd no that kit won't do anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MVK &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for a prompt reply. Well I did increase the idle spped a bit but I still get quite a bit of vibes. Also The drop in idle speed under electrical load is annoying. Any thoughts. Please I am really desperate. I just spent about 1200 bucks on this car. Everything else is so good even at 148k miles.
Thanks again.
MVK</TD></TR></TABLE>
THe drop in electrical load is normal during idle... Hell, i own a 2002 that does it when the fan, the radio and daylights are on...
fs
Old Jan 7, 2005 | 08:26 AM
Shehzada's Avatar
The grounding kit won't help with this problem. To clean your TB, spray some TB safe cleaner and work the butterflys back and forth. Be careful to catch all that gunk on some paper towel or something. After everything is clean, start the car and check for air leaks.
Old Jan 7, 2005 | 09:41 AM
twkdCD595's Avatar
check your motor mounts.
Old Jan 7, 2005 | 02:35 PM
C_H_A_D's Avatar
Default Re: Vibration at idle (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">check your motor mounts.</TD></TR></TABLE>
Read the post again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MVK &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1988 Honda Accord Lxi. I had some steering wheel vibration at idle esp when in drive. I was told by friends to change the motor mount. So I replaced both front and rear motor mount( The old one looks good though) Now the vibration got worst and car shakes violently at idle in drive. A little gas and vibes go away. What could this be?
Old Jan 9, 2005 | 03:18 PM
honda accord's Avatar
Default Re: Vibration at idle (Desslok)
hey man ur egr port is probably clogged...get it cleaned out..u should be good
Old Jan 9, 2005 | 03:59 PM
steve-o40's Avatar
Default Re: Vibration at idle (honda accord)
mine does it too...i cleaned the TB and it was fine after that...no problems since
escknx
Honda Civic (2006 - 2015)
May 9, 2014 08:15 AM
thisboyjulio
Sep 10, 2006 09:50 PM
flood
Mar 30, 2005 08:46 AM
boostin4drcivic
Feb 1, 2004 09:15 PM
mitch529
Feb 21, 2003 11:38 AM
