35mm Tail wastegate clearance
Old Dec 8, 2002 | 12:14 PM
khang77642's Avatar
Default 35mm Tail wastegate clearance
Does anyone have a problem with the clearance problem for the 35 mm tial wastegate ? Mines is hitting the top of the hood unless I remove the top vacumm source for the EBC? Can I leave it off ? Or can I do anything else ?
here's a pic w/ the wastegate pointing up.
Thanks, Khang
[Modified by khang77642, 3:41 PM 12/8/2002]
[Modified by khang77642, 5:12 PM 12/8/2002]
Old Dec 8, 2002 | 01:55 PM
Foozball26's Avatar
Default Re: 35mm Tail wastegate clearance (khang77642)
You can't post pics from imagestation.
I wouldn't leave the top port off, connect it to the EBC.
Either slam the hood down and have a little dimple in the hood, or get the 90 degree elbow so the wastegate will be horizontal and will clear the hood line.
Old Dec 8, 2002 | 02:00 PM
khang77642's Avatar
Default Re: 35mm Tail wastegate clearance (foozball-26)
Do you have any idea where I can get a 90 degree elbow? Thank alot
Old Dec 8, 2002 | 02:10 PM
TurboedGSR's Avatar
you can link images from imagestation, you just have to delete "orig.jpg" at the end.
I'd also like to know where i could buy an elbow and whats the price
Old Dec 8, 2002 | 04:33 PM
khang77642's Avatar
anyone?
Old Dec 8, 2002 | 04:36 PM
HXMan's Avatar
Hey, its my old kit! Hows the install going?
Old Dec 8, 2002 | 04:47 PM
khang77642's Avatar
Default Re: 35mm Tail wastegate clearance (HXMan)
yeah, everything went through smooth. I even polish the turbo too.. I need to get pics of the turbo for you ASAP.. I got more pics. The car started up w/o any problem with the hondata even though it took me a while to get it together. You gave me everything needed to put the kit together ... EVEN EXTRA SPARK PLUG !!! but you left a hole in the manifold hehe .... thank alot Levi.
here are just a few of them I already posted
http://www.imagestation.com/picture/...f/fcf49bc0.jpg
http://www.imagestation.com/picture/...7/fcf49bc5.jpg
http://www.imagestation.com/picture/...f/fcf49baf.jpg
[Modified by khang77642, 7:50 PM 12/8/2002]
Old Dec 8, 2002 | 05:04 PM
HXMan's Avatar
Lol...yea, I couldn't do much about the hole for the egt...it is in a pretty bad place too. But hey, I guess thats how to learn.
I'm getting another turbo kit though.......
How did the return line work out?
Old Dec 8, 2002 | 05:14 PM
khang77642's Avatar
hehe....yeah, dont worry I bought an EGT for the manifold already and the oil return line fits perfect. It goes around the downpipe without touching it. I bought a b16 oil pan already tap with -10 an bung but the oil pan didnt fit. So I had an extra -10an bung.... had to get it welded to the b18 pan.
for the oil feed line, it is little bit too long.. Is there any way I can shorten it ?
What kind of turbo kit are you getting and is it for your b16 ?
[Modified by khang77642, 8:15 PM 12/8/2002]
Old Dec 8, 2002 | 05:59 PM
Ben Huynh's Avatar
We offer the elbows for $35.00.
khang77642's Avatar
Default Re: 35mm Tail wastegate clearance (ben@importparts.com)
do you have a pic of the elbow ?
Old Dec 8, 2002 | 06:09 PM
ThePunk's Avatar
Here's a picture of the elbow we got from Ben@importparts...
Its for the drag kit on a GSR, but I think they're all the same..
Old Dec 8, 2002 | 06:13 PM
khang77642's Avatar
Default Re: 35mm Tail wastegate clearance (ThePunk)
cool, thanks alot bro
Old Dec 8, 2002 | 06:17 PM
Ben Huynh's Avatar
Thanks, they are all the same but you can order them for any wastegate you want.
Old Dec 8, 2002 | 06:23 PM
B18EG6's Avatar
even with the elbow, my wastegate STILL hits and continues to spiderweb my hood.
gsr in a hatch
Old Dec 8, 2002 | 06:24 PM
Ben Huynh's Avatar
Default Re: 35mm Tail wastegate clearance (B18EG6)
Keep in mind that the elbow is made for the DRAG turbo manifold but will fit others.
Old Dec 8, 2002 | 06:28 PM
khang77642's Avatar
Really. How bad is it though ? Will it dent your hood like it will on my setup . I rather spiderweb my hood than cause a lil dent on it. Thank alot.
Old Dec 8, 2002 | 07:00 PM
bretx0r's Avatar
ahhh just cut a hole in the hood
Old Dec 8, 2002 | 07:20 PM
B18EG6's Avatar
I know. I have a DRAG mani.
****...I was going to take a picture before I left. Its kind of sad... I have two spiderwebs from when I DIDNT have the elbow...and then one more from now when I DO have the elbow...
edit: I have a carbon fiber hood...My friend with the stock hood had a lil nip a doodle in his hood (errrr...dent)
[Modified by B18EG6, 11:21 PM 12/8/2002]
Old Dec 8, 2002 | 07:58 PM
b_edson's Avatar
In my GSR the wastegate hits, and I have a small dent in the hood. It's been hitting since March, and it's still just a little dent. Hasn't gotten any worse.
[Modified by b_edson, 9:59 PM 12/8/2002]
Old Dec 8, 2002 | 09:08 PM
BudaKai's Avatar
Default Re: 35mm Tail wastegate clearance (b_edson)
Do you think the JDM hood for an Ef would solve the problem of having that ugly little dent?
Old Dec 8, 2002 | 09:15 PM
GSRrR's Avatar
Default Re: 35mm Tail wastegate clearance (tzsir)
I think you use another fitting for the top. I think Dustin used one but I do not know which kind it was. I think that also clears the hood. The threads are different it will go in.
Old Dec 8, 2002 | 10:31 PM
PureTeg420's Avatar
Default Re: 35mm Tail wastegate clearance (GSRrR)
File down the top fitting. I took a good 1/2 inch off of it just to make sure, and still has lots of aluminum left and doesn't hit the hood.
Old Dec 8, 2002 | 11:13 PM
camp1320.com's Avatar
Default Re: 35mm Tail wastegate clearance (PureTeg420)
you really dont need the vacumm port on the top till you get a boost controller anyways.. so take it off until you get a boost controller... or call RevHard Mfg they have necks and custom necks for most manifold on the market..!!
Old Dec 9, 2002 | 02:48 AM
intekragsr's Avatar
Default Re: 35mm Tail wastegate clearance (camp1320.com)
my tial owned my hood, pics later
