anyone here use 14B or T25 on integra ??
i got a 2001 integra and its just gonna be sititn for a while .. i plan on puttin together a T25 or 14B turbo kit with drop shops manifold. i wanna keep my AC and the goodies such as that so have any of you had any problems with this set up ??? no possible to run a 2.5 inch mandrel bent downpipe etcc ?? i have an o2 housing off a 14B will that work with the T25 ?? and will that possibly clear my AC ? thanks !!!!
what i really want to know is if i could use the o2 sensor housing off the 14B on my integra and still clear the AC ..i made 2.5 inch downpipe for my friends home made turbo kit on his EF and it was a pain in the ***...
im going to be buying a T25 .. all its for is a lil more street power and my integras an automatic soo i think itll do good ...
>>Are you on crack? a 14b is perfect for a teg up to 15 psi<<
Naww, they're just Hondatech members.
I've been trying to figure out the "big turbo" fetish on this forum for awhile. A 14b is loafing until you're making power well in excess of 250 hp. I don't care how small it is. Power is all about moving air, and a 14b moves all the air a stock B18 can handle. Especially at less than 10 psi like most of us run...
i kinda wonder when you would get in and out of boost with this turbo. i really wish that someone who knows a lot more about turbos than me would make a list for when diferent common turbos will get in and out of boost on a b18. i guess that would take the fun out of th trial and error stage part
14b is tiny, u'll get plenty of midrange but it'll die quick up top, VERY quick. u can run 2.5 inch DP and keep all the goodies.
It really depends on the style of manifold you make, the postion of the turbo will decipher if you can use the stock 02 housing or not. More than likly you will need to get a custom o2 flange and built a custom o2 housing along with your downpipe..
similar to this,
Actually this pipe would be backwards on your setup, since we mount the compressor housings towards the driverside.
Btw, a 14b will work fine for your setup, the T25 is a pretty small turbo.
Jeff
similar to this,
Jeff
can someone tell me how mitsu turbos rack up to T turbo's? what is a 14b comparable to? 16g 18g 29g and the like
mitsu turbos seem to pretty plentiful and stock DSM turbos can be had pretty cheap
well i was just looking at an eclipse the other day and the factory turbo on that thing was about the size of a quarter, r u saying that a T25 is smaller than that
People take the 14b into the 12's on 1g DSM's
They peak out around 6200 on a DSM
the 14b on my CRX pulls like crazy till my redline at 7k. I would be willing to bet i would pull till 8k on a 1.6.
I have no experience with one on a B18 but i would be willling to bet you could pull that thing to 7k on it.
Good luck getting that DSM manifold to fit a Honda B-series, or any honda for that matter, its not even close.. The offset is way off for alignment on the ports.
Custom is the only way..
Jeff
Jeff
