fuel quality and pressure
Old Dec 8, 2002 | 11:01 AM
andrewasf77's Avatar
Default fuel quality and pressure
hey guys, how would i go about checking the quality of my fuel and the fuel pressure? thanks
Old Dec 8, 2002 | 11:02 AM
AssPenny's Avatar
Default Re: fuel quality and pressure (andrewasf77)
quality of my fuel
Ummm.... do they have fuel quality test kits?
Get a B&M or some other kind of fuel pressure guage
Old Dec 8, 2002 | 11:05 AM
Default Re: fuel quality and pressure (AssPenny)
not a quality test kit, but iwas going to take a little sample out in a glass jar or some and take a look at it. i thought i might have some contaminated fuel. and about the pressure, i was wondering where i should hook the guage up to.
Old Dec 8, 2002 | 11:16 AM
Eric R's Avatar
For your Rrrrrr...
Fuel quality:
Always choose a gas station with the newest fuel tanks. Old fuel stations without changing their gas tanks tend to have water in their fuels and it is not good for your gastank, fuel lines and injectors.
Always use the higher octane they have; some 92, some 93, even 94. Depending on brand and state.
Duh! If your keep your emissions system, always use unleaded fuel.
Pressure:
It depends on what you have done to your engine. I would keep the stock pressure for a stock engine setup. It doesn't help to increase the pressure in a stock engine.
Ideal pressure for your engine is around 52-53 psi. with vaccum line disconnected for stock injectors.
How to know? Install a fuel pressure gauge at the fuel filter or at the fuel rail, and a regulator of your choice. i.e. B&M, AEM, etc..
Good luck!
Old Dec 8, 2002 | 11:35 AM
Default Re: fuel quality and pressure (Tweety R)
what is that about the vaccum line?
Old Dec 8, 2002 | 07:44 PM
vtec.dc2's Avatar
vacuum line is connected from your fuel pressure regulator, once you have the gauge hooked up to fuel filter, you have to disconnect the vacuum an pinch it to get the reading, according to helms manual stock pressure should read anywhere from 47-54. i use b&m pressure gauge ($30).
jman86
Aug 26, 2006 08:13 AM
n_23_s
May 28, 2004 03:06 PM
d15b7racer
Aug 21, 2003 07:34 AM
toooslow
May 15, 2003 12:21 PM
