civic/CRX wiring
Old Dec 8, 2002 | 08:58 AM
Superhatch's Avatar
Default civic/CRX wiring
Just to let all of you know. The rear harness of a civic dosent match up with the plugs from a Crx si under dash harness.
90 Civic si rear harness plug.
91 si CRX under-dash plug to rear harness.
So Im wondering if I can straight splice, (id need schematics...wire colors dont match), or if I have to swap in the crx rear harness. Will the rear crx harness even work? I have an 88-89 CRX rear harness, is that compatable with the 90-91 CRX under-dash harness? I know the 88-89/90-91 harnesses have differences, but that plug looks like it will work.
Edit: the crx harness has 9 wires, the civic rear harness has 12...what are the extra 3 wires for?
Any, and all help is appreciated
-Jake
[Modified by SuperHatch, 11:59 AM 12/8/2002]
Old Dec 8, 2002 | 09:19 AM
Vinceg99's Avatar
Default Re: civic/CRX wiring (SuperHatch)
If its not one thing its another huh Jake?
Let me know if you need that rear harness so I can get it to you if you need.
Old Dec 8, 2002 | 09:53 AM
hybrid4dr's Avatar
Default Re: civic/CRX wiring (Vinceg99)
damn that sucks if u need i have a full civic SI under dash harness
Old Dec 15, 2002 | 06:15 PM
uneek4dr's Avatar
Default Re: civic/CRX wiring (hybrid4dr)
what are you tryin to wire in? i may be able to help
Old Dec 15, 2002 | 07:02 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I know for a fact the AC/Heat controls do not use the same plugs.
For one, the CRX uses electric motors to move the air select/vents, while the Civic uses a cable to do the same job.
Also, you will find differences even within CRX's. You cannot just swap a 90/91 cluster to an 88/89 CRX dash, they are wired differently.
Old Dec 15, 2002 | 08:58 PM
uneek4dr's Avatar
Default Re: civic/CRX wiring (uneek4dr)
hey man if you are swapping dashes the civic gauge cluster will fit with no problems just transfer the harness onto the cRX dash. thats what i did. then i found out the damn dash doesnt fit in a 4th gen sedan. the dash curves to much near the windshield so it has a nasty nasty gap
Old Dec 16, 2002 | 12:34 AM
Vinceg99's Avatar
He's not swapping out the dashes or anything his harness was cut in his hatch and hes trying to wire in a CRX under dash harness. He is now having problems with getting the rear section of his hatch to work with the CRX under dash harness there not the same...
Old Dec 16, 2002 | 01:02 AM
uneek4dr's Avatar
aahhhh i see.... good luck
Old Dec 16, 2002 | 12:02 PM
Urban Business
Guest
Posts: n/a
jake splice straight in. continuity test eveyrthing. once completed dead easy to splice.
akshn1
Aug 31, 2009 01:39 PM
thorclark
Apr 29, 2008 07:39 PM
dkrex001
Nov 12, 2007 03:07 PM
BlakeJ53
Sep 5, 2007 05:16 AM
chongfa_209
10
Jan 1, 2007 09:13 PM
