VAFC RPMs of Tach RPMs
Old Dec 8, 2002 | 08:11 AM
RAB's Avatar
RAB
Default VAFC RPMs of Tach RPMs
Ok I calmed down a bit, but i have a problem. I have the VAFC monitoring on RPM channel 1 ( so I get the big RPM read out.) What I've noticed is that the Tach and VAFC RPM are off. I'd say between the two the VAFC is about 300-500 RPMs lower than the Tach.
So which one is the ture read from the VAFC?....... I know there's been discussions about the fact the stock tach is off somewhat, but before I installed the VAFC VTEC would alway click over at exactly 5600. So it makes me think hmmmmmmm what did the VAFC do to my car
Old Dec 8, 2002 | 08:34 AM
blacklude's Avatar
Default Re: VAFC RPMs of Tach RPMs (RY8127)
Is it off that much in high rpms? I've heard in high revs the tach is about 400rpm off.
Old Dec 8, 2002 | 09:08 AM
illusion's Avatar
i would trust the VAFC. the honda tach is usually off
and i dont know about yours, but my vtec hits around 5200 stock
[Modified by illusion, 1:09 PM 12/8/2002]
Old Dec 8, 2002 | 01:03 PM
BoostedH23a1's Avatar
Default Re: VAFC RPMs of Tach RPMs (illusion)
did u set it up for a 4 cylinder.. most come setup for a 6 cylinder..
Old Dec 8, 2002 | 01:08 PM
piotrush's Avatar
According to the vafc, my switchover point was 5000 rpm, but 5200 on the tach. When I installed it, it was set at 5800, so I brought it down to 5200 on vafc. That was too high, so I brought it down even further to 5000. Is that your concern?
Old Dec 8, 2002 | 08:48 PM
RAB's Avatar
RAB
Default Re: VAFC RPMs of Tach RPMs (piotrush)
Ok I figured out my shift point. Its about 7800 on the tach, I used the hold function hey that's a pretty neato tool.
One last thing how do you read the pressure read out? i.e. what does it mean when you smash on the gas it goes to -180 and during normal driving its at -650?
Old Dec 8, 2002 | 08:53 PM
dvp95's Avatar
how did you find out your shift point with the hold function? i always wanted to know what my rev limiter is, but im afraid to take it to cutoff
Old Dec 8, 2002 | 09:56 PM
PrecisionH23a's Avatar
thats a very typical problem. when i used to have my s-afc it was off by 1000rpms. Numerous other friends of mine have an error on their v-afc/s-afc/avc-r, why? i have no clue. For some strange reason my avc-r recently just started reading correct values. Why? Like i said, i have NO clue at all.
Old Dec 8, 2002 | 09:57 PM
Alstare's Avatar
Default Re: VAFC RPMs of Tach RPMs (dvp95)
my MAP reading @idle is -555 pretty steady with an AEM intake on my 94 JDM h22a my highest was like -42 or so. The throttle angle in the gauge mode is still the coolest to look at I bought mine just to fix my fuel curve but it ended up bring me from 183WHP to 191WHP, needless to say I was happy. V-AFC gets a
HYREV2NR
Sep 11, 2003 06:21 PM
LeftCorner
Jan 6, 2003 03:54 PM
mntdewred
Jul 26, 2002 09:28 AM
BoostedGSRBubble
Jun 19, 2002 08:38 PM
4doorH22
Jan 4, 2002 09:50 AM
