spark plug wires problem
Old Dec 8, 2002 | 08:01 AM
Yokohama's Avatar
Default spark plug wires problem
I have a 1995 Civic CX with the 1.5L motor and i put in the ACCEL 8mm wires(only cuz i got them for a great deal at work and i needed new wires)but the problem is that the driver's side wires(sometimes both or sometimes just the far one) keep on popping out of the hole/s...they click in and all when i push them in but after about a mile i get the misfiring and pop my hood and viola wires are out... the hood blocks them from completely popping out...what could be the problem here...is it that they arent "seating" in or what...I'm lost.
Thanks in advance
Mike
Old Dec 8, 2002 | 10:02 AM
SoulSurfer's Avatar
Default Re: spark plug wires problem (YokohamaSiR)
Sounds to me like they just suck. Installing plug wires is not rocket science so I'm sure you're doing it right. I'd take them back.
Old Dec 8, 2002 | 10:27 AM
b19coupe's Avatar
Get OEM spark plug wires. Accel wires suck; as do most aftermarket spark plug wires.
Old Dec 8, 2002 | 02:04 PM
Yokohama's Avatar
Default Re: spark plug wires problem (b19coupe)
you guys are a lot of help!
Old Dec 8, 2002 | 02:15 PM
SoulSurfer's Avatar
We told you what it is...they suck which is why they're not sitting right. Get OEM.
Old Dec 8, 2002 | 02:17 PM
b19coupe's Avatar
If you want to stick with the crappy wires (not recommended), tie wrap them to the valve cover or use duct tape. OEM wires are about $45 and won't pop out, and will give your engine better performance. Your choice.
Old Dec 8, 2002 | 02:20 PM
Desslok's Avatar
DrivinVtec
Sep 10, 2007 07:02 PM
Eluzion
Apr 19, 2004 11:14 AM
acuraqc
Mar 12, 2004 03:02 PM
b16ahybrid
Feb 18, 2003 02:19 PM
phreaker
Nov 3, 2002 08:36 PM
