Highest compression I can go on regular pump gas?
Old Dec 8, 2002 | 02:42 AM
Evolsport's Avatar
Default Highest compression I can go on regular pump gas?
What is the highest compression I can go on regular pump gas?
Thanks!
Old Dec 8, 2002 | 06:25 AM
advanracing62's Avatar
Default Re: Highest compression I can go on regular pump gas? (Evolsport)
13:1 with good tuning. 12.5:1 if you want to be a little safer
Old Dec 8, 2002 | 08:00 AM
333's Avatar
333
Default Re: Highest compression I can go on regular pump gas? (advanracing62)
I thought 12:1 with Hondata tuning. And 93 octane
Old Dec 8, 2002 | 10:43 AM
BudaKai's Avatar
All depends on the piston design, but off the shelf components I' say 12.5:1 with good tuning.
Old Jul 16, 2009 | 04:36 PM
PacsterEg6's Avatar
i'm running 13:1 on Arias dome top pistons. no problems so far. u just need a good tune.
Old Jul 16, 2009 | 07:36 PM
Scott_Tucker's Avatar
Your static compression ratio had nothing to do with what octane fuel you need to use. With a properly cammed engine you could run 18:1 if you wanted. Formula 1 engines make 850 HP out of a 2.4 liter engine and run 85 octane fuel.
Old Jul 16, 2009 | 11:07 PM
delsolproblems's Avatar
Proper cams alone won't allow a honda motor to run 18.1 compression- don't try it. Professional racing engines are rebuilt often and aren't designed for idling. Even if you had a formula 1 motor in your car, you wouldn't want to run 18.1 comp unless you planned on rebuilding it fairly regularly. Higher compression adds more stress to the motor than any other method of power addition. The more compression, the shorter the life span of your motor. Sealing in the increased pressure and managing the extra heat are the two biggest concerns when calculating maximum possible compression.
Old Jul 17, 2009 | 12:44 PM
I wasn't insinuating that he should run 18:1, I was just saying it was possible with the proper cam. I disagree that increasing your compression ratio adds more stress than any other power adder. A properly built engine with 9:1 compression isn't going to last longer that a properly built engine with 13:1. They would be 2 different engines. The 9:1 would be a low rpm engine and the 13:1 would be a higher rpm engine. The effective compression ratio, which is the compression ratio measured fromt he point the intake valve closes, should be about 8 - 8.5:1 on most aluminum head 4 valve engines running pump gas. Note: The effective compression ratio is not the same thing as the static compression ratio.
down_the_hatch
37
Mar 30, 2011 07:36 PM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
sol_guy8569
Aug 26, 2004 08:45 PM
boostedblack99
Jul 27, 2004 08:18 PM
wickedEFguy
Feb 3, 2003 11:14 PM
