12 sec NA??
Old Dec 7, 2002 | 10:40 PM
J-Brooks's Avatar
Default 12 sec NA??
After reading a some recent post on NA and turbo R's my mind has begun to sway from going to turbo to stay na. Is it possible to hit 12's not like 12.99 but decently well into the 12's like 12.7, 12.8 or so. If so what kinda of things might help to do that. I actully have an ek coupe with an itr swap. Also keep in mind completely stripping the car is not an option...however somethings will be.
Old Dec 7, 2002 | 10:42 PM
Rob Dizzle's Avatar
Default Re: 12 sec NA?? (Type R Driven15)
200-220 whp
medium weight reduction (most all seats out & such)
excelent consitent driver
light weight wheels with slicks
Old Dec 7, 2002 | 10:44 PM
jdmspoonitr's Avatar
Thats gonna take lots of dough. And a lot of time on the dyno.
Old Dec 7, 2002 | 10:57 PM
92TypeR's Avatar
FSAE
Your engine is going to need to be a breather.
Toda C's + compression + ITB's + excellent header/exhaust + tuning = ~220 whp
You will also need slicks (or drag radials at the least) because you will be needing as much traction help as you can.
SgT would be a great person to talk to about trying to build a motor to reach that potential.
Old Dec 7, 2002 | 10:59 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: 12 sec NA?? (92TypeR)
ITB's not needed. And yes, talk to Steve (SgT).
Old Dec 7, 2002 | 11:13 PM
J-Brooks's Avatar
Default Re: 12 sec NA?? (Splat)
o I see. I don't really wanna take my seats out cause it is a daily driver. yea I am moving down to some 16" pro n1's or maybe rotas. None of you mentioned any kinda of head porting or resleeving or vavle jobs or anything. Alright for my other plan with the turbo I was going to resleeve the block get forged pistons and rods new head gasket and a new block for all this plus the turbo. I was looking at spending about 7-8 thousand. So with in those parameters what can I do. 7 gs enough cause I know Toda is up there. I forget how much for the Spec Cs. Those won't give me a rough idle will they??
[Modified by Type R Driven15, 12:14 AM 12/8/2002]
Old Dec 7, 2002 | 11:46 PM
J-Brooks's Avatar
bump
Old Dec 8, 2002 | 12:55 AM
skafia's Avatar
25 Year Member
I'll be happy with a 13.9 in my ITR
Old Dec 8, 2002 | 01:20 AM
2dark2bslow's Avatar
bro, youre gonna need all of the above block work...depends on what head youre using...im gonna see what i make with 84mm sleeved block and forged internals, higher comp and cams...tunign is a given.
you should ckeck out http://www.importbuilders.com , real nice and knowledgable guys. ship them your longblock and theyll have it back to you making as much as you want, all depends on your pocket book.
good luck
[Modified by 2dark2bslow, 10:20 AM 12/8/2002]
Old Dec 8, 2002 | 01:46 AM
GokuSSJ4's Avatar
. you dont need ITB , thats what my goal is at pamdale (which should be no problem ) and corrected time would be mid 12's ...
Ericksracing B18c 2.0L
12.3CR
Toda Spec D cams
FD 4.9
440cc
Hondata (and lots of tunning )
[Modified by Spoon1, 10:50 AM 12/8/2002]
Old Dec 8, 2002 | 07:09 AM
Davanca's Avatar
Man you going to have a rough idle with TODA C's. I friend of mine was getting 12.86 out of his Type-R. I don't know much about his setup, but i know he was running a 13.1 compression and he had the head ported and polished with toda b's. I don't know what pistons he was running or what he did to the block, i do know it was an ITR block though. He had slicks also on slipstreams.
Old Dec 8, 2002 | 07:38 AM
Tommy_Gunns's Avatar
Boost
Old Dec 8, 2002 | 07:57 AM
naturalvx's Avatar
If your plans are to have comforts and go 12s you already going down the wrong path. You have a EJ coupe (EK=hatch) and you want to go 12.7 NA it better be VERY light, so expect to get every bit of that weight out or make some serious HP, in which your drivability will be slightly different (IE not that great of idle, etc).
Old Dec 8, 2002 | 08:19 AM
Rob Dizzle's Avatar
Default Re: 12 sec NA?? (naturalvx)
there is a guy on here that i met at a meet. he is sponsored by area 51
he had just basic motor work. stock bottom end and aggresive cams. then converted to 4 lug because of lightness and being able to put smaller slicks on
he was into the 12's
Old Dec 8, 2002 | 10:50 AM
baonest1's Avatar
Default Re: 12 sec NA?? (Bob-DC2)
ive put 10K in my motor.. some stuff i got for free that would cost a bit. im shooting for low 13's or even 12's.. but its gonna take timeee and lotsa mullaaaa
Old Dec 8, 2002 | 11:16 AM
J-Brooks's Avatar
Default Re: 12 sec NA?? (baonest)
I see, so its looking like the turbo is gonna be better choice as far as having the time and having the comfort and being daily driven. O well thanks for the information.
Old Dec 8, 2002 | 12:23 PM
Smitdog's Avatar
Gordon or Bustanutt-616 is consistent in the high 12's with his Jun 3 setup and Hondats tuning. Check out SGT's site http://www.SGT-Racing.com, Gordons' R is the PY one, shows his setup.
Old Dec 8, 2002 | 12:29 PM
MackSpeed-616's Avatar
Default Re: 12 sec NA?? (Smitdog)
i think ill be looking to sell my car soon, if any1 is interested in 12sec itr out the box for less than 20k ill be entertaining offers.
Old Dec 8, 2002 | 12:39 PM
itr1244's Avatar
Default Re: 12 sec NA?? (BustaNutt-616)
It will be probably cheaper if you went turbo
baonest1's Avatar
hmm.. the site isnt working for me. busta--whats yer bottom end?? stock or built. thanx
Old Dec 8, 2002 | 12:40 PM
baonest1's Avatar
Default Re: 12 sec NA?? (itr1244)
it would, but not if you build it all up, like bottom end and everything. it would cost about the same, but yeah turbo would give you a bit more POWER
Old Dec 8, 2002 | 12:44 PM
itr1244's Avatar
It will be probably cheaper if you went turbo it would, but not if you build it all up, like bottom end and everything. it would cost about the same, but yeah turbo would give you a bit more POWER
that's true.
if someone wants to go fully built turbo.. yeah of course it will cost more than fully built n/a but..
Old Dec 8, 2002 | 12:47 PM
all stock with ctr pistons
Smitdog's Avatar
No, dont sell it Gordon.............
Old Dec 8, 2002 | 12:55 PM
baonest1's Avatar
thanx.
