CEL code 20...
Old Dec 7, 2002 | 09:43 PM
HondaCutter's Avatar
Default CEL code 20...
I know its Electrical Load Detector circuit, but I want to know what kind of problems are associated with this circuit going bad, and do I need to get this from Honda or can I get it from any auto parts store?
Old Dec 8, 2002 | 01:22 AM
3gLudeH22A's Avatar
Default Re: CEL code 20... (HondaCutter)
I had a code 20 CEL due to an unplugged knock sensor...So the first thing you need to do is check all of you sensors...you may not have one hooked up or bad circuit. Also check your grounds.
Old Dec 8, 2002 | 01:35 AM
Kataku2K3's Avatar
Default Re: CEL code 20... (3gLudeH22A)
You sure you didn't have a code 23... I really don't see how you fixed an ELD code by plugging in your KS.. The ELD is located inside the main fuse box under the hood... Peace
Old Dec 8, 2002 | 10:47 AM
Camshaft's Avatar
what car year trim level, engine set up are you running
I have seen some resistors set up so you supply 2.5v to the ELD wire and the codes goes away
cam
Old Dec 8, 2002 | 04:33 PM
Default Re: CEL code 20... (Camshaft)
92 civic dx w/ obd2 LS swap with obd1 ls ecu
Old Dec 10, 2002 | 06:45 PM
Camshaft's Avatar
http://www.hondata they had something in the forums
The ELD wire to the ecu.....
They took 2 Resistors one from ELD to 5v and another from eld to ground.
So that the ELD would get 2.5 volts.....
91efbluehatch
21
May 30, 2017 10:19 AM
Austin.em1
Jan 1, 2014 07:32 PM
GriFFIthS
Honda Civic (2001 - 2005)
Feb 21, 2011 04:26 AM
ralpheezy
Aug 16, 2007 09:50 AM
b18civic
Feb 18, 2002 03:58 AM
