brakes
Old Dec 7, 2002 | 05:49 PM
S13 slide's Avatar
Default brakes
ok, i have a brake problem, when i step on the brake, the pedal goes way down more that it should, its really soft too, and when i step on it, its kicking back a little. i thought it was a warped rotor, so i changed both rotors and pads. but its still there. what else would cause this problem? also when i step on the brake, the open door and seat belt light comes on and beeps. any ideas? could this be a caliper sticking problem? or master cylinder? thanks
Old Dec 7, 2002 | 06:38 PM
the DR.'s Avatar
Default Re: brakes (S13 slide)
sounds like you have air in your brake lines, try bleeding them. or you might have a leak somewhere.. as for the seat belt light thing, check your brake lights, i'm betting the fuse blew.
Old Dec 9, 2002 | 06:34 AM
CXHatchback's Avatar
Default Re: brakes (CIVICtypeS)
def check your m/c too
OogalyDoogaly
Honda Motorcycles
Apr 6, 2009 01:28 PM
yeegsr
11
Sep 15, 2004 12:12 PM
iperez
Jul 14, 2003 09:36 PM
SpeedKnight
10
Jul 9, 2003 01:47 PM
S13 slide
Dec 2, 2002 04:50 PM
