"splitting the case"
Old Dec 7, 2002 | 03:49 PM
Nameless RB26's Avatar
Default "splitting the case"
I took my tranny off w/the clutch housing. Can someone tell me (because I have no helms right now) what needs to be done to pull the case off the clutch housing?
It doesn't want to come off, and I don't want to **** something up..
Old Dec 7, 2002 | 04:02 PM
jonas's Avatar
Default Re: "splitting the case" (Nameless)
i believe theres 16 bolts that hold the case together.. if i'm not mistaken. someone correct me.
1. remoe the back-up light switch
2. remove the transmission hanger
3. remove the set screws, springs, and the steel *****.
4. remove the reverse idle gera shaft bolt
5. loosen the 16 bolts that olds the housings together in a crisscross pattern.
6. remove the 32 mm sealing bolt
7. expand the snap ring on the countershaft ball bearing and remove it from the groove using a pair of snap ring pliers
thats all from the helms infront of me
Old Dec 7, 2002 | 04:35 PM
Default Re: "splitting the case" (jonas)
Thanks!
Old Dec 7, 2002 | 07:30 PM
sneakychaos's Avatar
Thats my guess as to what you missed.
SolTym
Oct 5, 2004 01:21 PM
0ptimus prime
Jul 17, 2004 11:17 PM
wutangben
Jun 15, 2003 08:19 PM
dwtyper
Dec 30, 2002 07:24 PM
type r 01-1063
Jul 17, 2002 09:24 AM
