For the love of Honda, someone please answer this Hybrid Swap Question!!!!
Old Dec 7, 2002 | 01:04 PM
slow02ss camaro's Avatar
Default For the love of Honda, someone please answer this Hybrid Swap Question!!!!
Ok I have a 2000 H22a4 in my 94 Accord LX...I converted to 5-speed at the same time. My question is regarding the tranny mount and bracket. Which combination do I use?!?! Obviously neither mount nor bracket from my auto tranny would work. I'm not sure if the Accord mount bracket will bolt onto the lude tranny. So basically, when you 5-speed guys buy your h22 and drop it in, does the motor come with the mount bracket or do you use the Accord or do you buy a new lude one??? I went to the track last night and broke my rear motor mount b/c the motor sits too far to the drivers side. I know it has to be that I have the wrong combo of the tranny mount and the mount bracket. Currently I have the lude bracket and mount. I bought the Accord mount at the same time when doing the swap and they look identical( the lude and accord tranny mounts)!! So I would assume I'm running the wrong bracket but someone please tell me either way so I can fix my ****!!! PLEASE! I've posted this before with no real answers, and I've searched, again with no defintes.
[Modified by slow94accord, 10:06 PM 12/7/2002]
Old Dec 7, 2002 | 03:54 PM
Default Re: For the love of Honda, someone please answer this Hybrid Swap Question!!!! (slow94accord)
come on...i wanna go to the junkyard tomorrow and get the right part...help a brother out!
Old Dec 7, 2002 | 04:09 PM
KTeller8's Avatar
all i can say is this
i know they only use the driver motor mount from the 92-96 lude everything else is accord..
now i did the auto swap in my 96 and i did the same only used the driver lude motor mount..
might be way different with your generation accord
Old Dec 7, 2002 | 04:20 PM
Default Re: For the love of Honda, someone please answer this Hybrid Swap Question!!!! (KTeller8)
the 96 is the same...so you used the accord tranny bracket on a lude tranny??...it bolted right onto the tranny?
Old Dec 7, 2002 | 06:19 PM
Sleeping4drLS's Avatar
this might help... http://www.h22a.org/5gswap.htm
Old Dec 7, 2002 | 06:53 PM
ArchAngel Sabastian's Avatar
New User
yes accord bracket lude tranny
edit in the 96 im working on the auto to man swap used the accord tranny brac. so i assume its the same.
[Modified by ArchAngel Sabastian, 9:53 PM 12/7/2002]
BigDaddyRich
Oct 27, 2011 11:31 AM
93JDM_H22
Jul 1, 2010 12:04 AM
SQ is the SQUAD
Welding / Fabrication
Nov 15, 2005 07:12 PM
Jdm91Teg
May 15, 2005 08:53 PM
Scorch7
Dec 27, 2002 02:30 PM
