Using EX vtec solenoid on a b16.
Old Dec 7, 2002 | 10:02 AM
LsVtecDA's Avatar
Default Using EX vtec solenoid on a b16.
Would you be losing any kind of power, or are there any drawbacks on using a vtec solenoid off of a EX on a b16 head? Thanks.
Old Dec 7, 2002 | 11:59 AM
Kataku2K3's Avatar
Default Re: Using EX vtec solenoid on a b16. (LsVtecDA)
You aren't going to be loosing power... A VTEC solenoid is a VTEC solenoid... I've never done this personally so I don't really know if it bolts up... You probably know better than me... I checked http://www.hondaautomotiveparts.com and they show a different part number for the D series and B series VTEC solenoids... If it bolts up you should have no problems, but i just don't know.... Good Luck
Old Dec 7, 2002 | 02:19 PM
salbaje's Avatar
it should work the only problem is that the harness might hit one of the plugs
Old Dec 7, 2002 | 02:35 PM
LsVtecDA's Avatar
Default Re: Using EX vtec solenoid on a b16. (salbaje)
Are EX solenoids the only ones where the oil pressure swith faces out towards the front of the car?
Old Dec 7, 2002 | 03:11 PM
Kataku2K3's Avatar
Yea i guess it would face foreward... You can see that will be different cuz on an EX motor with the VTEC solenoid being bolted on the back of the cylinder head the VTM sensor faces towards the passenger side of the car.... When you swing that around to the side of a DOHC VTEC motor it's now going to be facing foreward... Never thought about this before... here's a pic...
Old Dec 7, 2002 | 05:51 PM
qcoffey's Avatar
Default Re: Using EX vtec solenoid on a b16. (JDMspecEG6)
A buddy of mine is running a SOHC distributor and VTEC switch on his B16 swap. The car produces good horsepower numbers. He has a JDM B16 and is putting down 154 to the wheels, so I don't think you'll have any problems.
Old Dec 7, 2002 | 05:53 PM
Kamin's Avatar
Default Re: Using EX vtec solenoid on a b16. (qcoffey)
um
they are the EXACT SAME SOLENOID, the only diffrence is one of the plugs is in a diffrent location on the d16. but you will see no change from one to another.
Old Dec 8, 2002 | 08:41 AM
LsVtecDA's Avatar
Default Re: Using EX vtec solenoid on a b16. (KAMiN)
Does anyone know if the Vtec solenoids off of 92-95 EX are different from those off of a 96-2000 EX? I have what I think is two EX vtec solenoids, but they are different.
Old Dec 8, 2002 | 11:37 AM
Chugger's Avatar
i have a d16z6 vtec solenoid on my b18c fits fine just looks kinda goofy
thats all
plug fits fine just sticks out a bit
but they all fit 92-95 sohc vtec as well as 96-2000 sohc vtec
thanks
chris
Old Dec 8, 2002 | 12:30 PM
LsVtecDA's Avatar
Default Re: Using EX vtec solenoid on a b16. (Chugger)
Do the 92-95 and 96-2000 look the same though? or are the different?
Old Dec 8, 2002 | 12:50 PM
Kataku2K3's Avatar
They should look the exact same...
Old Dec 8, 2002 | 02:54 PM
B19CivicHB's Avatar
Im using a 93 VX VTEC solenoid on my 96 JDM GSR engine. Works like a charm. VTEC pressure sensor plug is a little out of the way, but works none the less.
-Nick-
Old Dec 8, 2002 | 04:51 PM
LsVtecDA's Avatar
Default Re: Using EX vtec solenoid on a b16. (B19CivicHB)
Thanks to all. I believe my problem has been solved.
HXMan's Avatar
Nice info to know. I have a couple extra SOHC VTEC selonids sitting around. If I get a JDM swap I will be sure to use one.
matt2320
Sep 19, 2007 07:58 PM
christin
14
Dec 13, 2006 10:30 AM
importtuner07
May 7, 2006 12:35 PM
DC2Teg
Sep 19, 2004 08:00 AM
ek9 ferio
20
Mar 10, 2004 06:01 PM
