A THANKS to all the guys on this board !!!!
Old Dec 7, 2002 | 09:23 AM
NixTEG's Avatar
Default A THANKS to all the guys on this board !!!!
I had bought a 90 Integra and with a bad rod bearing and built it by myself from the ground up !! I had come on this board WHILE i was building it to do research on what would fit and mate with each other . All the information i got from this board was pretty much ACCURATE !! I mated a JDM b18B Motor to a b16 tranny with a TYPE R clutch and pressure plate !! I had to rewire a coolannt sensor and reroute a coolant line but i had to figure that one out myself and after i put everything together the car ran ******* GREAT !!
After a few months little problems arose ( the car has 270, 000 kms on it )
1) ignition switch went - someone on this board helped me on this one
2) fuel pressure regualtor went - someone on this board helped me on this one
3)Fast Idle air valve went - someone on this board helped me on this one
4) Alternator went - i figured this one out, common sense
5) And finally the disributor went - i figured this one out ,common sense
THANKS to this board this car HAS NEVER SEEN A TOW TRUCK or a MECHANIC !!
All WORK done by me !!! WITH hand tools and a test light !!
THIS IS ONE OF THE BEST BOARDS OUT THERE !!! thanks to YOU GUYS ON THIS BOARD !!
There are many boards out there that talk about crap like how they can't get laid ( like i really care ) or what to buy their girlfriend on their birthday .
But this board is probably one of the best one's out there
[Modified by SlowCivicNick, 6:27 PM 12/7/2002]
[Modified by SlowCivicNick, 6:29 PM 12/7/2002]
Old Dec 7, 2002 | 12:09 PM
tnbigdawg's Avatar
Default Re: A THANKS to all the guys on this board !!!! (SlowCivicNick)
been there, done that
I'm glad everything worked out for you.
isn't this place great!!!
BUDSHAD1
Oct 19, 2012 05:55 AM
jfruauff
Jan 13, 2009 12:59 PM
crazykid9137
Jul 26, 2007 09:41 AM
95civicgsr
Aug 25, 2006 11:51 PM
Type R 702
Nov 18, 2001 05:01 AM
