Seen4Ever....this info is for you
you said u ran those times with your JRSC...well..first off i have a 4th gen lude, with a JDM h22..so i have shorter gearing to start with, and there are quite a few people with 4th gen lude running very low 14s, and there a guy running 13.8s with his usdm lude on slicks..comparing my car to a 5th gen just makes no sense...and my car weighs in at almost 2900 with me in it..im sorry if my bolt on lude running the same times as your Supercharged one upsets you...but if u really want em to, ill post the slip, btw..it also wasnt a fluke run, ive run 14.0 about 9 times...thanks
And also to the guy that asked "How is that possible? When your in neutral, you can't rev past 6500rpm."
You launch in 1st gear, not neutral....
