Where is oil pressure switch on 97 GSR need to remove it for JRSC!!!!!! help
Old Dec 6, 2002 | 09:51 PM
DeDonDeRosa's Avatar
Default Where is oil pressure switch on 97 GSR need to remove it for JRSC!!!!!! help
it tells me the "unplug the oil pressure switch" but i can find it does anyone know where it is and what it looks like
some please help me out
Old Dec 6, 2002 | 11:55 PM
B16A1-EF9's Avatar
Default Re: Where is oil pressure switch on 97 GSR need to remove it for JRSC!!!!!! help (DeDonDeRosa)
The oil pressure switch that they are talking about is most likely the one pin sensor on the back of the motor next to the oil filter. This sensor turns on the oil ight on the dash. There is also another sensor called the VTEC oil pressure sensor which is on the head.
What exactly are you doing that you need to find this switch, that might help us give you the right answers. At what stage are you in the JRSC install.
Post up some pics when it's done!
Old Oct 31, 2004 | 06:26 AM
B16CRXT's Avatar
Default Re: Where is oil pressure switch on 97 GSR need to remove it for JRSC!!!!!! help (B16A1-EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A1-EF9 &raquo;</TD></TR><TR><TD CLASS="quote">The oil pressure switch that they are talking about is most likely the one pin sensor on the back of the motor next to the oil filter. This sensor turns on the oil ight on the dash. There is also another sensor called the VTEC oil pressure sensor which is on the head.
Post up some pics when it's done!</TD></TR></TABLE>
Is this the swith that must beremoved for the tuner toys dual outlet fitting?
M-benz
Oct 8, 2013 04:56 AM
jillygirl13
Honda CR-V & Element
15
Jun 11, 2012 06:55 PM
Jaz760
Mar 15, 2011 04:41 PM
JDM_Acccord
Jul 5, 2007 09:29 AM
SleeprCivic
Jun 21, 2003 02:07 AM
