bigger brakes and 15" wheels
Old Dec 6, 2002 | 07:34 PM
mattt's Avatar
Default bigger brakes and 15" wheels
I'm most likely to be roling on 15" wheels next summer on my 97 civic sedan. I sould like to know what options are available to get better braking.
Are 99-00 Si front calipers bigger than the other 6th gen civics? Or is the itr the only "larger" caliper option? Any aftermarket kits with large caliper/disk assembly available to fit 15" wheels?
Also, I drive my car in winter... what brake pads do you think would be appropriate?
Old Dec 6, 2002 | 11:21 PM
Extreme's Avatar
Default Re: bigger brakes and 15" wheels (mattt)
Fast Brakes has several options for big brakes that fit 15" wheel
http://www.fastbrakes.com/pages/kits.htm
Old Dec 8, 2002 | 05:48 AM
QCKGSR's Avatar
Default Re: bigger brakes and 15" wheels (Extreme)
yes, go to fast brakes they have reasonable kits with good products
Old Dec 8, 2002 | 09:13 PM
civic23g's Avatar
Default Re: bigger brakes and 15" wheels (QCKGSR)
I have a 96 civic sedan and i have GSR brakes all the way around and it stops pretty damn good. I beleive the fastbrakes is the only other good option.
Old Dec 10, 2002 | 09:50 PM
mattt's Avatar
Default Re: bigger brakes and 15" wheels (civic23g)
I'm thinking of getting a set of used 15" enkei rp02 wheels, also might have got a good deal on montegi mr7's in 15"... anyone know if these wheels offset will be ok when I get around to bigger brakes like the one's suggested here?
Or should I just stick to eom Si or teg wheels?
Old Dec 10, 2002 | 10:10 PM
jdmDXrex's Avatar
i would just stick with 15" wheels or bigger wheels and big brake kits....
Personally i would just go with 15" wheels and spend the money on a motor. unless you really need more braking power.... but to each his own.
ChaseIntegra
Suspension & Brakes
37
May 21, 2012 06:17 PM
H24Turbo
Mar 4, 2009 06:30 AM
Blazin Si
43
Jun 7, 2003 04:47 AM
