lightened Flywheel ?
Old Dec 6, 2002 | 11:38 AM
RiceNmotioN's Avatar
Default lightened Flywheel ?
What would be the ideal flywheel weight for a road/rally use turbo B? I've seen some that are 9lbs. but I think those are better suited for drag cars. Could someone fill me in on the stock flywheel weight and the streetablility of a flywheel weighing 9lbs? I'm looking for a broad power band, not a top one.
[Modified by RiceNmotioN, 8:41 PM 12/6/2002]
Old Dec 6, 2002 | 11:44 AM
Spade's Avatar
Default Re: lightened Flywheel ? (RiceNmotioN)
The only issues with a lightened flywheel is inital launch. Once the car is rolling the lighter the better.
Old Dec 6, 2002 | 03:05 PM
chevyalltheway's Avatar
lightened flywheels are not as well suited for drag racing. in drag racing heavier flywheels are much better.
Old Dec 6, 2002 | 03:08 PM
Desslok's Avatar
Default Re: lightened Flywheel ? (chevyalltheway)
But for AX or Rally
Old Dec 6, 2002 | 04:43 PM
00 Meanie's Avatar
Jun or Toda makes 4.5 lb. Stock ITR's is 13lb
Old Dec 6, 2002 | 05:21 PM
Kataku2K3's Avatar
Default Re: lightened Flywheel ? (00 Meanie)
I would rather have a JUN or a Toda just for the name, but the Clutchmaster one works well and it weighs about 9lbs.... Latez
[Modified by JDMspecEG6, 6:22 PM 12/6/2002]
Old Dec 6, 2002 | 07:42 PM
10K2HVN's Avatar
Default Re: lightened Flywheel ? (JDMspecEG6)
i thought stock ITR was 15 lbs...with the other B-series at 18 lbs...does anyone know a flywheel at 12 lbs..?
Old Dec 7, 2002 | 04:06 AM
sauceman's Avatar
Sorry, this is a little off topic, I know, but can you explain why the lightened flywheel is not suitable for drag racing? This notion is new to me, I need clarification.
Jeff
Old Dec 7, 2002 | 06:56 AM
eg6ajk's Avatar
Default Re: lightened Flywheel ? (sauceman77)
Jeff
simply put, stored energy. once heavier flywheel is spinning, it simply stores more momentum, which is mass x accleration. momentum is what keeps you going once you are moving. therfore heavier flywheel is spinning at 8000rpm as well as lighter one. the heavier will have more energy which it passes onto the tranny. find Mista bone he has done some testing on d-series on flywheels and found that lightweight and drag wasn't any better.
stock can be machined to 12lbs or so without much structual damage to the flywheel.
JUN and few others sell 10-11lbs flywheels. I personally run stock GSR (18lbs), ITR (15lbs), shaved stock (12lbs) and then Cusco and Toda at 8-9lbs.
from the testing 12lbs seemed like the best compromise as it gave me best overall feeling in acceleration
Old Dec 8, 2002 | 09:09 AM
333's Avatar
333
Default Re: lightened Flywheel ? (siblue-sol)
I have the CM lighten flywheel. I believe it was 9lbs and I am running 18 psi. I really have not noticed it at all. Just on take offs. Car shakes and shutters but I have a ACT 6 PUCK clutch and Poly mount. Not a big fan of the lighten flywheel. Bought one because mine was cracked.
Old Dec 8, 2002 | 10:44 AM
10K2HVN's Avatar
Default Re: lightened Flywheel ? (333)
Your car shakes and shutters too huh...thought it was just my car...but i dont know what clutch i have..its suppose to be a ericks racing dual diaphram tri puck..but ive never seen it before...
Old Dec 8, 2002 | 11:21 AM
Kataku2K3's Avatar
Default Re: lightened Flywheel ? (10K2HVN)
Like a Tilton??? One of these bad boys....
They are like $1300 but look bad ***.... I haven't heard much about it yet and am curious.... Peace
Old Dec 8, 2002 | 12:09 PM
R@mon's Avatar
i dont know why but that last picture kinda scares me, it doesnt look very strong around the edges....
Old Dec 8, 2002 | 12:54 PM
10K2HVN's Avatar
Default Re: lightened Flywheel ? (93h22a4)
cromoly steel...its strong enough...
Old Dec 9, 2002 | 04:48 AM
Mista Bone's Avatar
D Tranny Guru
yummy, twin disc!
Old Dec 9, 2002 | 09:12 AM
rolow's Avatar
n e one know the website that lightens stock flywheels to around 12lbs. i saw on this board a while back but i forgot the site.
http://www.inlinefour.com
My bad its resurfaced
[Modified by rolow, 6:19 PM 12/9/2002]
Old Dec 9, 2002 | 10:53 AM
Katman's Avatar
Marcus at Heel/Toe sells stock-lightend flywheels for about $200, check it here:
http://www.heeltoeauto.com/
Old Dec 9, 2002 | 11:45 AM
gotnothing's Avatar
Default Re: lightened Flywheel ? (hndarcr)
Just didn't want to start a whole new thread...
I don't know much at all about clutches. I plan on getting an Action Clutch, just a stock upgrade street disc, mainly because the quality is decent and the price is pretty nice. I would like to install a new flywheel at the same time. Any recommendations? I'm considering various aftermarket flywheels, since I can get some of them cheaper than the stock from Acura, but should I bother? Can I use an ACT StreetLite flywheel with an Action Clutch? As far as I can see, the answer is yes, but I'm research-obsessed...Any other ideas for a clutch?
[Modified by gotnothing, 3:51 PM 12/9/2002]
Old Dec 9, 2002 | 12:10 PM
RosSi's Avatar
New User
Default Re: lightened Flywheel ? (eg6ajk)
Nitpicking, but momentum = mass x velocity. Mass x acceleration = force. Otherwise, good explanation.
Old Dec 9, 2002 | 02:24 PM
Default Re: lightened Flywheel ? (RosSi)
Thanks guys, I'm still a little skeptical on chromoly, but it it seems to be okay for flywheels.
Honsu
Mar 22, 2004 04:34 PM
EFb18b
Jan 8, 2004 06:40 PM
Nealoc187
Apr 1, 2003 09:51 AM
Quik Chris
Feb 5, 2003 01:02 PM
far
Jun 22, 2002 11:44 PM
