Heater/Defroster Problems
Old Dec 6, 2002 | 08:05 AM
xXsarcasmXx's Avatar
Default Heater/Defroster Problems
I have checked all fuses and the are good, checked the hoses and theyre hooked up good, but the heater still wont go on. Im assuming it has to do with wiring... does anyone have a diagram of how the wiring should be and any other ideas on what might be the problem.
thanks in advance
Old Dec 6, 2002 | 08:13 AM
USDM 4G VTEC's Avatar
Default Re: Heater/Defroster Problems (xXsarcasmXx)
Fuse 18-rear window , ac and power door mirrors
i wil check the climate control for bad and loose conectors, blown fuse... does ur rear window def works?? the blower?? anything at all??
Old Dec 6, 2002 | 08:25 AM
Default Re: Heater/Defroster Problems (JDM EF9)
the rear doesnt work but I think thats just a fuse but the blower doesnt come on or anything.....
Old Dec 6, 2002 | 10:29 AM
WuShu's Avatar
New User
throw some external power to the blower and see if its the blower then just retrace from there.
Old Dec 6, 2002 | 10:32 AM
Vinceg99's Avatar
Default Re: Heater/Defroster Problems (HondaCRX)
For your blower motor it could be either your switch in the controls or your blower motor resistor. Or your whole blower motor might be bad.
Old Dec 6, 2002 | 12:01 PM
Wiz's Avatar
Wiz
listen to hondacrx - he knows heat
Old Dec 7, 2002 | 10:14 PM
Default Re: Heater/Defroster Problems (Wiz)
sounds good....I'll let you know the verdict
kickz
Aug 22, 2022 06:48 AM
James Blair
Honda Civic (2006 - 2015)
Mar 17, 2013 05:04 AM
toronto_thunder
May 2, 2008 06:36 AM
94Gizzer
Mar 5, 2003 04:11 AM
CRX Si
13
Jan 26, 2003 07:02 AM
