throttle body sizes
Guest
Posts: n/a
heres some info i colected. havent ever seen it in a centralized place so here you go:
http://www.hondaswap.com/articles/viewer.php?id=51
edit: DOH! you have to make an account at hondaswap.com to view it aparently. its free. my listing is under the "latest tech articles" section
[Modified by TorteX, 10:31 AM 12/6/2002]
Guest
Posts: n/a
heres the jist if you dont want to make an account: all sizes are inside diameter
b18c1 60
b18c spec R 62
b18a 58
b18b 60
b16a SiR 58
b16a Sir2 / b16a2 / b16a3 60
b20b/z 60
f20c 62
d15b7 56
d16a6 55
d16y7 56
d16y8 56
d16z6 56
ZC 55
d16a1 55
d16a8 55
h22a / h23a 60
f22 / f23 60
dpfi d15b1 and d15b2 have to be added havent had time to measure them.
[Modified by TorteX, 10:33 AM 12/6/2002]
b18c1 60
b18c spec R 62
b18a 58
b18b 60
b16a SiR 58
b20b/z 60
f20c 62
d15b7 56
d16a6 55
d16y7 56
d16y8 56
d16z6 56
ZC 55
d16a1 55
d16a8 55
h22a / h23a 60
f22 / f23 60
Will the B18b TB (60mm) swap over to the 1g B16a? What mods are needed if any? Is the MAP sensor on the B18b TB like the B16a2? I know where theres one I can get. Thats the only reason I ask.
Thanks for the info.
Guest
Posts: n/a
How big can you go with the D16A6?
Guest
Posts: n/a
I have a machinist taking a spare TB that I had and is going to work it a bit for me... .001" over stock, and losing the cone shaped intake walls; it's going to be the same size down the body, with new blade and reworked TB shaft. I know I'm going to lose air velocity, but I'll have more air volume... is the trade off worth it?
I'll still keep my hands on the stock TB to T -n- T, so either way I'll be aight. Just curious.
great info. this should be at the top again to help others. one question, do i need anything from the stock TB like the tps or anything like that? or will my tps fit up to it (d16z6) thanks
[Modified by tek_civic, 12:36 PM 2/2/2003]
doh i threw away my dpfi d15b1 manifold
Now all we need is a definitive list of which TB's have the same bolt pattern, I guess I could check out part #'s of TB gaskets and see which engines use the same gasket. I was accually thinking about using an F22 TB on my D16A6, but someone told me that all F series, and all D series were the same size. Now that I know better, I no longer have access to that TB
[Modified by thumpu77, 3:13 PM 2/2/2003]
From: the asshole of america..., upstate new york, USA
which side are you measuring from? the inlet side or the side going to the manifold (since its a slight taper)? cause i measured about 1mm bigger for both the b18a and the y8. but thats on the inlet side.
denraweb
Oct 13, 2007 05:54 PM
