attn: bodyshop pros
Old Dec 6, 2002 | 04:34 AM
DeLiRiOu5's Avatar
Default attn: bodyshop pros
i need some info on molding in a urethane lip to a bumper. if the process isn't too bad i'm gonna attempt to mold my wings west rear lip into my bumper and possibly shave the rear sidemarker.
this is for a 96 honda accord by the way... thanks
Old Dec 6, 2002 | 04:53 AM
DeLiRiOu5's Avatar
Default Re: attn: bodyshop pros (DeLiRiOu5)
kinda like this but with the sidemarker shaved too
[Modified by DeLiRiOu5, 5:54 AM 12/6/2002]
Old Dec 8, 2002 | 04:23 PM
DeLiRiOu5's Avatar
ttt
Old Dec 8, 2002 | 05:17 PM
qcoffey's Avatar
There are many different seam sealer products that can be used. I have a Greddy front lip on my '99 Si that broke in about 5 different places, I even lost a small section. My body man used this urethane repair/seam sealer and we sanded and shaped and you could never tell it was broken. Go to your local automotive paint supply store and ask them for this type of product. It is exspensive but it won't crack or expand and it can be shaped. This is one application where fiberglass won't work. Good Luck.
The product costs about $30 per tube and $4 for the special tips. You also need a special application gun.
[Modified by qcoffey, 2:18 AM 12/9/2002]
Old Dec 8, 2002 | 05:23 PM
DeLiRiOu5's Avatar
Default Re: attn: bodyshop pros (qcoffey)
so ask for urethane repair/seam sealer?
do u know the process by chance? i'm thinking its like, squeeze some out of the tube in the crevice between the bumper and lip... let it dry for a few minutes and sand it down smooth?
and is the application gun the same as the ones used for silicon?
thanks a bunch
Old Dec 8, 2002 | 05:24 PM
FredoTheChimp's Avatar
here check this out: http://gtimatador.vwmafia.net/gallery/gallery.html
Old Dec 8, 2002 | 05:29 PM
qcoffey's Avatar
thanks a bunch
No the gun is not the same. The product I believe is made by 3M. And of course they come out with their own gun.
Basically the job is how you describe it wait till it dries and go to town. There is a 12 hour dry time though.
Old Dec 8, 2002 | 05:35 PM
DeLiRiOu5's Avatar
cool... thanks for the help
i have one last question and will probably sound stupid... but what are the differences between wet sanding and just regular sanding? or is it the same process but with wet sandpaper? i've worked with fiberglass and have never had to wet sand so i'm not too familiar
Old Dec 8, 2002 | 05:38 PM
qcoffey's Avatar
Wet sanding is a process is typically done after the car is painted. It is usually used to get out any minor imperfections in the clear.
Old Dec 8, 2002 | 10:09 PM
tnbigdawg's Avatar
what you really want to get is "plastics/urethane repair". A company called Duramix produces some of this stuff. Or you can use plstic welding.
Seam sealer is a different product used to seal panel joints, usually seen in the engine bay, and trunk area.....so its basically a soft rubbery glue-which is NOT what you want.
[Modified by tnbigdawg, 11:19 PM 12/8/2002]
Old Dec 9, 2002 | 12:58 PM
ef civic's Avatar
Default Re: attn: bodyshop pros (tnbigdawg)
hey you guys think the seam sealer or the urathane repair would be good for molding in a wingwest sideskirts on a 90 civic hatch?
Old Dec 9, 2002 | 01:45 PM
tnbigdawg's Avatar
Default Re: attn: bodyshop pros (ef civic)
I wouldnt use that stuff on metal cause it might delaminate from it later on down the road.....because metal, and plastics have different expansion rates.
Old Dec 9, 2002 | 02:16 PM
qcoffey's Avatar
The best thing to do is to ask your local automotive paint supply store. You can use a seam sealer (there are many different types for different applications). That is why it is good to ask someone that caters specifically to bodyshops not PepBoys. Most sealers remain flexible so even if the skirt flexes a bit it won't crack.
Old Dec 9, 2002 | 03:04 PM
RenoRacing's Avatar
duramix is truly amazing, i've never used the urathane stuff but the fiberglass adhesive is great for gluing on fender flares. so strong!!! but the gun alone is like 50$, 26$ for the adhesive, and like 12$ for 5 tips.
phat00civic
Paint and Body
Feb 22, 2012 03:52 AM
shutta
Jul 9, 2006 04:52 PM
type-t
Nov 17, 2004 07:40 PM
elprelude
Jan 11, 2003 11:50 PM
b18bEG
Aug 9, 2002 09:21 PM
